How use Phonon with mini2440
Jaquouille
Hi all,
Does anyone use Phonon with the mini2440 board ?
If yes, could you please explain how to configure environement (QT
Creator).
Jack
I saw that in the ./configure of Qt4.6 there is an option -phonon. I tried
to set it enable but unfortunatly the following error appears :
> Phonon support cannot be enabled due to functionality tests!
>  Turn on verbose messaging (-v) to ./configure to see the final report.
>  If you believe this message is in error you may use the continue
>  switch (-continue) to ./configure to continue.
Can anyone help me please ?
mouha
bonne chance ça répond pas des masses ici
Eric
how to cross compile phonon and phonon back end plug-in for mini2440
john
its strange that no body know about Phonon on arm9...
Juergen Beisert
Try a look into our PTXdist, it is able to build Phonon. Maybe you get an
idea how to do it correctly.
