Hello, I follow all the steps printed in the good tutorial of domodom,, but today activesync is still not working ( works with CE5.0). I regenerate an image in visual studio where i check : - CoreOS/cebase/Application-enduser/ActiveSync - CoreOS/cebase/CoreOs services/USB Host support/ USB remote NDIS Class Driver -Device driver/USB function/USB function client/Mass storage, RNDIS client and serial. When i run the image, active sync detects anything, and no connection is detected by the mini2440. Please have you any ideas ? thks fred
WINCE 6 activesync
Hello, My activesync still not work although i think i follow all the domdom's steps. I note an other pb: when i build the CE image in visual studio by selecting "Build\ build mini2440 release", the image is generated, but is alway at 22Mb, even if i change some components in the catalog. If i build selecting "advanced build settings\sysgen", i have random compilation failure ( no specific module, it could be wininet.dll, ole32.dll ... depends on time .... ). Please can you give me some advice ? Thank you Fred
Try to make a sysgen clean. And delete the old nk.bin to be sure that the nk.bin is generated. domodom
Hi domodom, I kill all the re-generated directories, and my compilation passes successfully. But the actual nk.bin always stays at 22Mb, and activesync still not work. I check all the items of CEBase/core os services/Usb host support ( including Remote ndis driver ). some remarks : -In the mini2440, i cannot find regedit to look into the registry... What are the dll i need in the mini2440 to execute activesync ? Thank you for your help fred
Another test you can make is to use the english BSP downloadable on this site. Activesync should work. I don't have better idea... (for the moment ?) Domodom
Hello, i try this and i have the same behaviour. I note someting else in visual studio : in the Third party, i would like to ckeck usbfunctions. when i select it, a red cross appears... is it an installation problem of the bsp or the compiler ? Fred
During boot, i get the following message : Exception 'Data Abort' (4): Thread-Id=04160002(pth=83a82600), Proc-Id=00400002(pprc=82008308) 'NK.EXE', VM-active=048b0002(pprc=839ffe10) 'explorer.exe' PC=c092b790(sc2440usbfn.dll+0x0000b790) RA=c092b788(sc2440usbfn.dll+0x0000b788) SP=d2adfdc0, BVA=00000007 I really think there is a pb with the "sc2440usbfn.dll". I try to recompile it manually, but i get the same error...
I work on the subject again, and i ask me if the problem doesn't come from my software configuration : i use visual studio 2005 on WINDOWS VISTA : does anyone use vista as OS ??? Fred
Did you install Service pack for Vs2005 for vista? http://www.microsoft.com/downloads/details.aspx?familyid=90e2942d-3ad1-4...
now it's working.... VS2005 was not faulty but i had to install all packages of windows ce, up to wince R3. And now ( maybe due to the correct framework ) all demos of friendlyarm work ( i2c, leds, screen, button )... Fred
I installed VS2005 succesfully. I also installed CE Tools and all the releases from MS Site up to R3. When I open the BSP I get a list of errors. Look at this image http://www.eyegps.gr/vs2005.png Any ideas ? Am I missing sth ? Thanks
My problem seems to be just like fred_from_france's. But I have already installed wince 6 up to R3. I still have the problem that no connection or unknown device is detected in my pc while connected to mini2440 running wince 6
