Java Virtual Machine
azzido
It is possible to run Java bytecode ?
Linux 2.6 has JVM installed ?
"www" directory contains JWebcamPlayer.jar and source code for this jar.
azzido
Have someone installed JVM on mini2440 ?
Engr. Mohazzab Javed
i have installed java virtual machine midp2.0 from phoneme and it works
fine but it is on windows ce 5.0 if you want any help regarding
please mail me at
moh_bim@yahoo.com
Mehmet
I want to run Java Program on Linux. is it possible?
Please help me.
My project is waiting.
Mehmet
Please help me.
mehmet_ozcan6@hotmail.com
azzido
Yes, it's possible. This week I have installed JVM from phoneMe. It works
great. Now, on my target runs server web developed using Java.
If you need more informations please contact me at p.nicusor@yahoo.com
or nicusor.popescu@continental-corporation.com
Mehmet
Thank you for your answer.
I know it this JVM is for JavaME. I want to run JavaSE Project on Mini2440
azzido
Yes. You can JavaSE but 1.4 version is required.
Here is translated in english a tutorial about How install JVM on Mini2440
runs on Linux:
http://translate.google.com/translate?hl=ro&ie=UTF-8&sl=zh-CN&am...
When you must to make a binary try this command:
make CVM_INCLUDE_COMMCONNECTION=true J2ME_CLASSLIB=foundation
for more classes.
JVM is from https://phoneme.dev.java.net
Berun
Hello!
Has anybody sucsessfully installed Java on the Mini2440 with Qtopia/Linux ?
If yes. Can anybody please give me a quick and dirty how to?
Berthold
Berun
P.S. I ask because the Tutorial is down!
Berun
my mail: boerdy.braun*at*ish.de
Mitul
Pl. provide the tutorial on JVM in Qtopia/Linux.
my e-mail: mitulpanchal17@gmail.com
bob
You may be better sticking to the Android version,
Yes it is not exactly java , but the issue you are going to have is with
setting up the graphics under java, it can become very "wordy"
That is to say >70% of the code space is generally destined to  getting
graphics in place.
your next issue is that the java system is memory intensive.
if you ever load "java" into linux even with version 1.4 you can easily eat
up 20-40mb of ram.
So you are going to need a slim version.
start here
http://java.sun.com/javame/reference/docs/sjwc-2.2/pdf-html/html/build/l...
PoL
You can try with jamvm and gnuclasspath i have it up and running, even got
apache tomcat to run. Good luck
Fábio
I'm having trouble with cross compiling JamVM on Ubuntu 10.4.
I used the compiler that comes with the Mini2440 DVD.
Can you post the steps to compile and install JamVM?
Yi287italp Ertem
I got Java Virtual Machine working with Qtopia 2.2.0 linux. Used this
tutorial, it's not that hard to follow. If you have problems regarding to
this how-to, i can try to help.
http://translate.google.de/translate?hl=de&sl=zh-CN&tl=en&u=...
Other than that i have a problem. With this JVM there are only some io,
util libraries are builtin. I need to create GUI (may be swing) with java,
is it possible to add the libraries i want to this phoneme thing? Anyone
can help about it?
widyo
It is possible to run javaSE on mini2440. Once i've had it on my mini2440.
I got mini2440 with 64Mb nand, so i mount(bind mount) my mmc card at
/usr/lib/jvm to add more storage.
Since it was not quite good performance with java on my system, then i
removed it --my howto documentation also :(.
Can't really help, just want to say that it is POSSIBLE to have JavaSE on
your mini2440.
cheers,
sanjeev
I have installed MySufiy jvm for mini2440 but java files r not executing
it showing Class not found error please tell me how to set the classpath
if any one used this jvm
sanjeev
hi all please help me how to install jvm on linux qtopia
i want to run j2se application on mini 2440 please sugggest me the jvm
and hoe to install it
