CE6 does not persist
salavatov
Somehow CE6 image only runs one time, in NOR mode just immediately after
downloading. After reset in NAND mode it show start logo but not loading
anything.
What is interesting, CE5 image works just fine. So it seems problem is in
my CE6 image or nboot_T35.bin which I got from wince6-bsp_20100106 package.
Thanks,
Kostya
matt_Damon
May be this is a problem with the VIVI version.  Try to correct VIVI in the
NAND flash
salavatov
I have version 2 in NOR.
After x and v of supervivi-0945-2K in NAND mode it says wrong lunux
partition.
domodom
I think you should update your NAND Flash bootloader :
http://www.domodom.fr/spip/Mise-a-jour-du-bootloader.html?lang=en
Domodom
salavatov
why you think so? CE5 work fine from NAND. CE6 seems not booting and I
guess it is due to mistake in BSP. Do you have good working CE6 BSP with
Debug config support?
Thank you,
Kostya
salavatov
how I can verify version of vivi? What version are good?
domodom
No, debug don't seem to work, but i didn't try to find why. But it works
fine in release.
I had the same problem as you at the begining.
salavatov
domodom, why you think it is problem of bootloader? (you mean NOR vivi I
believe, right?) CE5 persists just fine. So I believe my NOR vive is fine.
Is it possible to verify version of vivi in NOR prior to re-flashing?
Thanks,
Kostya
domodom
I think it's a bootloader problem because i had the same and it have been
resolved by flashing a new bootloader. I flashed the both bootloaders with
the same supervivi file (as explained on my website).
The supervivi source code ise closed, then it's difficult to understand
this type of problems....
I don't know how to know the supervivi version, i have this in the menu of
my supervivi :
and
[i] Version: 0945-2K
domodom
salavatov
domodom, you mean [i] Version: 0945-2K is the option in vivi console?
I have ##### FriendlyARM BIOS 2.0 for 2440 ##### in the title already. Does
it mean my NOR vivi is up to date?
Thanks,
Kostya
salavatov
and I do not see option "[i] Version: 0945-2K" on your pictures of vivi at
your website.
Thanks,
Kostya
domodom
Yes, the "[i] etc" command is missing on my picture, but i have it now.
It is possible that i made the pictures before to update my bootloaders...
domodom
