Hi, I want to work on mini2440 with out OS. I am using Keil 4 as a compiler. But It is required to down load .bin to the board & keil 4 is giving .hex file. I also tried (simple led flashing program) to generate .bin file from .axf file & also from .hex file. But that didn't work. Can anybody suggest me the proper solution? ThanX, Rohit
How to do with Keil 4
How to debug with Keil 4 ? On Keil 3 I defined in Project->Options->"Debug" tab I chose "RDI Interface driver" and H-JTAG server. In Keil 4 this option is absent. What to do?
Lemik - look in H-JTAG (V.1. or later) folder and run ToolConf.exe. It will edit your TOOLS.INI and you will now be able to choose "H-JTAG" for Debug. ARM are gradually removing RDI, and it has already completey gone from their larger RVDS suite and remains at the moment only in the cheaper Keil tool suite. P
hello friends. i m a little new to this processor. i have been working mostly on processor with built in ram & rom. i have worked on arm7 in keil & have been successful. since this processor has external rom & ram, i m little confused. i have this module with 64mb sdram & 1gb of nand flash. i am trying to setup keil uvision4 for it but i m kinda finding it diificult. actually i want know details on setting up rom & ram details in the target option.(address setup for nand flash & sdram) so can u guys help me out or atleast if u have an keil project can u guys send it me or upload it somewhere from which i can download? i wud really appriciate it thanx n regards naqsh
Hello naqsh! I have a same type kit that you. And have the same doubt that you! :) If you found some information, please tell me, and if i found, I can also inform you. nilsao@gmail.com
Hello all, I am very new to KEIL 4. I am using Keil 4 as a simulator. I am creating a project with .obj files and I am able to get the output on UART#1 window on debugging aslong as the .obj files are very small but if the .obj file is slightly bigger on and the project runs for more than 15 seconds the output is being replaced with the new one making my output useless. Can any one kindly help me in this regard by suggesting how I can increase the size of UART window or redirect the output to a notepad which can increase the size of it automatically. tilak1169@gmail.com
Hello davef, Its a licensed version for 1 year. I tried it on evaluation version also but I can not build slightly bigger .obj files as we have code size limitation. - tilak1169@gmail.com
Hello all , I have a mini6410 (target = s3c64101A) which compiler can be used to compile a code and generate the bin file. keil 4 only has s3c2440A . thanks in advance.
In the device database in keil uvision4 i could see the processor S3C2440A but when i create a project and try to assign the target,I couldnt see the same processor in the list.What might be the problem??
