Dear all I've seen surfing the blogs and other websites that sometimes it is recomended to use arm-none-linux-gnueabi-gcc to compile, and sometimes it is arm-linux-gcc. Do you know what are the differences between those two tools? I have not searched deeply, I've seen they were installed with arm-linux-gcc 4.3.2, and there were some symbolic links also. Any idea? Regards
Gcc compiler
The only explanation I could find was that -none will guess how to compile, from the source code extension, .c or .cpp And that was after a lot of searching.
The ABI stands for "Application Binary Interface " and is including the ARM Procedure Call Standard (APCS), ARM ELF, ARM DWARF, etc... From ARM we can find this definition : "The specifications to which an executable must conform in order to execute in a specific execution environment. For example, the Linux ABI for the ARM Architecture. " In fact, the both came from EABI architecture with the difference with that EABI (the new one vs OEABI old one) you have more improvements : - better implementation for floating point ops that lets using mix harware & software floating point operators, - others syscall is in the R7 register to know the caller instead re reading after an interrupt (SWI) - for the v4 & v5 architectures ==> the s3C2440 embed the ARM920T that is made from the V4 - these differences come at the linker step where the diffs betwen OEABI and EABI are made cf 'ARMIHI039B p8' - data structurations The most important is that you CAN use both, but you CAN NOT mix them: - if you used OEABI untill now, go on with it, even though it will be painfull for you as most of compils are EABI - using EABI is the better solution for me as most of the libs are EABI-oriented Choose one of these both, because using EABI with OEABI libs is not possible, what I told before should explain why. If usefull I could post a more precise explanations into my blog (English/French/Italian only) =DL= _______________________________________________ my sources ARM : [url]http://infocenter.arm.com/help/index.jsp?topic=com.arm.doc.subset.swdev....] - Debian Wiki
Hello, Thank you for that information. So I understand it's better to use arm-none-linux-gnueabi-gcc than the arm-linux-gcc coming from the same install package. But I don't know why in some cases (seen on the web) arm-none-linux-gnueabi-gcc succeed where arm-linux-gcc fails. Thanks again
In which cases did it failed ? By the way, this looks like that what I said : in some cases if someone had compiled with OEABI (libs for example) you will had compatibility troubles. =DL=
