python on mini
david
hi im tring to install phyton on mini im following the steps of this link:
http://www.ailis.de/~k/archives/19-ARM-cross-compiling-howto.html
i made the cross compile with out mistake (i only saw some warnings)
at the end i did this:
To install python type this:
# make install prefix=<Root-directory>/usr \
HOSTPYTHON=./hostpython \
BLDSHARED="arm-linux-gcc -shared" \
CROSS_COMPILE=yes
Notice that you have to specify /usr behind the path to the targets
root-directory.
You are done. You should now have a complete working cross-compiled Python
suite. Copy it to your target machine and be happy
MY DOUBT ITS what folder or files should i copy to the mini2440?
and .. how exactly i know the python its working well on my mini? (i never
have worked with python before).
Thanks to every body
david
hi i copied the all folder to the mini and after that i put on console
./python
and appears me this:
Python 2.2.1 (#1, May 24 2010)
GCC 4.3.2 on linux2
Type help, copyright or license for more information.
then should i assume that i made a good installation of phyton?
(forgive my ignorance i never have use phyton before)
it is ok good and i hope this can be useful for someone else :)
What size flash have you got in your machine?  After cross-compilation I
had somewhere around 64M, which was a bit large for my 64M machine.  I
understand one can strip out a lot to reduce size.  Did you do that?  If
so, what did you remove?
david
my phyton folder size its 71Mb im luck because my mini board size its 128m
however 71mb its to much for my mini2440 i want to reduce that size, but im
not sure yet what i have to remueve.
i would like that you tell me if you find the way to reduce it
thanks!!
Did you find this tutorial:
http://randomsplat.com/id5-cross-compiling-python-for-embedded-linux.html
I see at the bottom there are some suggestions for reducing size.
Flávio Ribeiro
Hey David, can you put your python binary package on some repository so
people here can download an run it?
thanks
david,
Following the link in my previous post.
cd _install
rm -rf include
rm -rf share
cd lib
rm libpython2.6.a  (wasn't present)
cd lib/python2.6
rm -rf `find . -name test`
rm `find . -name *.pyo` (didn't work, wrong syntax)
rm `find . -name *.py`  (didn't work, wrong syntax)
rm *.pyo (worked for me)
rm *.py  (worked for me)
cd ../../bin
rm python2.6
Got _install down to 31.5M
Now, the line
ppc_6xx-strip python
I couldn't find the equivalent for the arm9
Good luck,
dave
david
davef i tried to do my compilation following your link but i couldnt able
to do it
how ever i tried to do my own compilation (the one what i put above) and
now im having some trouble with the last step:
CROSS_COMPILE=yes
its showing now this mistake:
bash: Root-directory: No existe el fichero ó directorio
i dont know what im doing now wrong, however the crosscompile file it
working as worked the first one i did (so strange dont you think?)
./python
GCC 4.3.2 on linux2
both files when i type characters like  (  on mini it throws doubles ((
and when i type supr it shows me [[3
but when i type credits or copy right it showsme that and if i type
print 'hello world' it shows me hello world
i had never work with python so i dont know if this problem (supr) its
normal or i did a wrong compile
the size of my file its:40.7Mb
dave your does you python has this problems? could you help me with this?
Flavio i suggest you follow the instrution of my link or davef's link maybe
you will not have my problems.
and also suggest that the first who put this work well  put this python
binary package on some repository.
david
davef when i try to compile following your link i have problems in this
part:
CC=ppc_6xx-gcc CXX=ppc_6xx-g++ AR=ppc_6xx-ar RANLIB=ppc_6xx-ranlib
./configure --host=ppc-linux --build=i686-pc-linux-gnu --prefix=/python
make HOSTPYTHON=./hostpython HOSTPGEN=./Parser/hostpgen
BLDSHARED="ppc-linux-gcc -shared" CROSS_COMPILE=ppc_6xx-
CROSS_COMPILE_TARGET=yes
make  install HOSTPYTHON=./hostpython BLDSHARED="ppc-linux-gcc -shared"
CROSS_COMPILE=ppc_6xx- CROSS_COMPILE_TARGET=yes
prefix=~/Python-2.6.5/_install
im coping and pasting these lines and its showing me this:
/Escritorio/Python-2.6.5$ CC=ppc_6xx-gcc CXX=ppc_6xx-g++ AR=ppc_6xx-ar
RANLIB=ppc_6xx-ranlib ./configure --host=ppc-linux
checking for --enable-universalsdk... no
checking for --with-universal-archs... 32-bit
checking MACHDEP... linux2
checking EXTRAPLATDIR...
checking machine type as reported by uname -m... i686
checking for --without-gcc... no
checking for ppc-linux-gcc... ppc_6xx-gcc
checking for C compiler default output file name...
configure: error: C compiler cannot create executables
See `config.log' for more details.
david
ops i forgot my python files can be run from my USB in this way the size
shouldnt be so important.
david,
"Size shouldnt be so important".  Why spoil all the fun?!
Correct me if I am wrong, but it looks like you are cross-compiling for a
ppc rather than arm9.
Here are the commands I used:
./configure --host=arm-linux --build=i686-pc-linux-gnu --prefix=/python
--enable-shared --disable-ipv6 --disable-dynamic-extension
CFLAGS="-march=armv4t -mtune=arm920t -Os -lpthread -lrt" LDFLAGS=${LDFLAGS}
BLDSHARED="arm-none-linux-gnueabi-gcc -shared" CROSS_COMPILE_TARGET=yes
make  install HOSTPYTHON=./hostpython BLDSHARED="arm-none-linux-gnueabi-gcc
-shared" CROSS_COMPILE_TARGET=yes prefix=~/Python-2.6.4/_install
Try these and let me know how you got on.
Dave
flavio
hey dave, can you put your python somewhere so i can download it?
flavio
ups david, sorry, i didnt read your message to me. Okay so its time to try
to cross compile it right now.
flavio,
It is untested so I think posting it would just waste people's time.
For now, if you get a successful compilation following the aforementioned
tutorial using my script mods you will be as far as I am.
I need to do some study on 2D plotting capabilities in Python before going
any further.
OK?
dave
flavio
Ok, i compiled python 2.6.5 and it works with a couple of built-in libs
(os, sys and others).
threading, time and some don't work, but if you want to see python running
on your friendlyarm you can download this binary and test:
http://dl.dropbox.com/u/6159957/Python-2.6.5-FriendlyARM.tar.gz
flavio
its important to say that it wasn't tested much and i'll work more to get
all modules working.
flavio,
Excellent.  I'll check it out tonight after work.
Did you find a strip command for ARM9?
Could you post the steps you took after the 3 commands I posted?  Or did
you use a different method?
Regards,
dave
david
flavio i checked your python and it has the smae problems as mine
if i put "(" it appears doubles
if i use delete appears = ?
if i use supr [3
david
davef im having some troubles when i execute your second line:
*** WARNING: renaming "ossaudiodev" since importing it failed:
build/lib.linux-i686-2.6/ossaudiodev.so: cannot open shared object file: No
such file or directory
Failed to find the necessary bits to build these modules:
_bsddb             _hashlib           _tkinter
bsddb185           bz2                dbm
gdbm               readline           sunaudiodev
To find the necessary bits, look in setup.py in detect_modules() for the
module's name.
Failed to build these modules:
_curses            _curses_panel      _sqlite3
_ssl
what could i be doing wrong? thanks
david,
Sorry, I can't really help with that.
What host distro are you using?  I did mine on Ubuntu 9.04.
Dave
david
Davef im using ubuntu 9.1, maybe i have installed wrong my toolchain i only
installed the arm-gcc compiler do i need to install some thing else on my
pc??
david
The excuse what i installed was arm-linux-gcc-4.3.2 toolchain from this
link:
http://equallybad.blogspot.com/2010/02/project-how-to-setup-default-dev-...
is it enought with that or do i need some thing else thanks!!
david,
Just read through this again and was wondering if you had made any
progress.
In order to get Ubuntu to compile stuff you need:
sudo apt-get install build-essential automake autoconf libtool
Also, to be able to look at <menuconfig> when doing kernel work you need:
ncurses-dev ? or ncurses something.
I think those are the only extra things I had to drag it.
Good luck
david
davef i formated my pc i made the process again but following your
instrution i couldnt complet the cross compilation.
the only way i could made it was following the instrution of the first
link:
it compied with out mistakes but has the same problems than the other at
the moment i typed delete or supr
although if i type copyright it shows me
all rights reserves ....
can you upload you file? i want to check if it has the sames issues
I'll look into placing it somewhere so that you can download it.
Haven't done it before!
Dave
david,
Try this.
Download-Link: http://rapidshare.com/files/397383730/Python.zip.html
Now, the issue about stripping Python.  Appears it is the normal strip
command, but what the switches are used and what files you want to strip I
haven't a clue.
Good luck,
Dave
david
davef,
yes it works as my python, and also it has the same size.
thanks friend
david
davef i forgot what python's version did you compile?
2.6.5
david
thanks friend
what i compile was 2.2.1
Jesse
I downloaded the python that Davef compiled and it seems to be working
except for a few modules.
I'm trying to install pySerial and the install bombs out with this error:
error:  Invalid python installation unable to open
/usr/local/lib/python2.6/config/Makefile (no such file or directory)
If I just copy pySerial into the folder then I get hung up on these modules
when I do an import on serial:
fcntl
termios
struct
select
time
Thoughts?
Jason McHuff rosecitytransit.org
Don't know if the "unable to open /usr/local/lib/python2.6/config/Makefile
(No such file or directory)" problem has been solved, but what you need to
do is install python26-devel.  I got the same error and installing it fixed
it.
BaHko
Is there any new progress on Python to mini2440.
I have been trying to compile Python-2.7.2 / Python-2.7.3 from this site
But with no luck.
Any one that have working Python-2.7.* at all?
ron
for...
http://blog.sina.com.cn/s/blog_81a58dbf01013sre.html
