Adding delay between SPI transfers
Trinath
I am trying to add delay to spi_ioc_trasnfer struct in my application code
like this below (.delay_usecs). I am testing this on DSO but the delay
between each transfer is always less than 25usec. (to be precise, 22us
delay after first transfer and 11us after then.)
        struct spi_ioc_transfer tr = {
                .tx_buf = (unsigned long)txptr,
                .rx_buf = (unsigned long)rxptr,
                .len = noBytes,
                .delay_usecs = 1000,
                .speed_hz = speed,
                .bits_per_word = bits,
struct spi_ioc_transfer is defined in /include/linux/spi/spidev.h.
Any suggestions please....
Trinath
Trinath
Also,
Why ioctl() trasfers need atleast 2 bytes to transfer? Got segmentation
fault when tried to send one byte.
Xristos
I have to write an application that sends 1 byte via SPI and receives one.
Is that impossible?
Cxxx
I'm guessing that when you tried to transfer a singe byte that you gave
.tx_buf and/or .rx_buf a number instead of a pointer, which when referenced
is very likely to cause a segfault.  makesure txptr and rxptr is a
pointer/array
Xristos
Now I send the byte as the first cell of a table, so it is a pointer and it
works.
I still do not understand why it receives the byte of the previous
question!
I just use a workaround.
