Serial port trouble
sameer nalawade
Hello all,
          I have mini2440, which i am using for communication with a serial
printer and serial cheque reader.
          I tried serial communication with my local machine using gtkterm,
i can send data from mini2440 to my machine but can not send data from my
machine to mini2440.
          I also tried hyperterminal but still same results.
          I am setting the baud rate using a c program and confirming it
with another program, so baud rate might not be the problem.
          When i used the "echo <some_text> /dev/ttyS0" command from my
machine to send data to serial port i received some data on /dev/ttySAC0
but only once or twice, it didn't show any data after that. I can send data
to my machine though but not vice versa.
          Can anybody please suggest what could be problem with serial
communication?
Thanks,
-sameer
sameer nalawade
Hello all,
         I have resolved the problem. It was just that i had to direct  the
kernel debugging messages to other port than /dev/ttySAC0. Now i can do the
serial communication both ways :)
         Now i am using mini2440's ttySAC2 with a serial cheque  reader but
all i am receiving is some garbage data. Does anybody have any idea about
this? I have checked it for different baud rates, parity bits, stop bits.
Please help
Regards,
sameer
JazzD
just an idea, maybe the data from that reader is binary?!
lalitha
hi sameer,
 how did u change the baud rate??? did u tried with polling mode r
interrupt mode??
david Kaplan
A few questions please.
Would you mind explaining what are all the changes needed in order to
switch the debug channel to ttySAC2 or the USB?
Is it possible to do this in user mode or only by way of a kernel
recompile.
I need to use the RS232 channel for project control.
After the change, will it still be possible to update the kernel using the
standard tool?
 Is it possible to update the kernel using only the USB and maybe the
Ethernet channel?
sameer nalawade
Hi Lalitha,
         You can change it in serial port settings, there is a dropdown
list of baudrates or u can use any small c program to change baud rate.
Regards,
sameer
indrajeet
Hi sameer,
I m trying to use UART0(on mini2440 board) for interfacing the ARM board
and a motor drive controller. For the same i have written UART driver which
will be used by my application to transmit n receive data. But I m facing
problem in intializing the UART0(serial port). I m receiving garbage on the
minicom wen i transmit some data thro my application.
can u let me no wat is the possible solution to this. or do i have to
use other serial ports available on the board bcoz UART0 is already being
used by the kernel.
eagerly waiting for the reply....
indrajeet
Hi sameer
can please brief me about how u actuaaly directed the kernel debugging
messages on other port. i think I m having the same problem. wen i send
data to minicom I receive garabage on the terminal..dat probably i think is
the kernel debugging message bcoz I m using UART0...
It would be great of u if you can help me out as early as possible...
Indrajeet
ebtr1
Hi all,
   Is it possible to create a communauty project to share knowledge on the
serial cheque reader program for mini2440 ?
lalitha
Hi Sameer,
  can you share your code which working fine...
Actually I have tried using termios but read is getting blocked for
carriage return in Canonical mode and time & character limitation in raw
mode ...
so please send me how did u achieve serial communication for arm9 board in
Linux..
suresh
Hi all,
have you solved the problem, I am also facing the same problem.
my setup is below,
serial motor controller from sparkfun
(http://www.sparkfun.com/commerce/product_info.php?products_id=9571)
mini2440 com2 port
connectivity is below :
com2 port- TX(pin 1)   to  motordriver -RX
com2 port - RX(pin 2)   to motordriver-TX
I am using termios library & using ttySAC2 driver(/dev/ttySAC2). Actually
there is no /dev/ttyS0-S2 in the /dev folder.
So ttySAC0-2 is the driver- is that correct?
I dont know whats wrong in the program/connectivity, motor is not
controlled.
program is below. can someone help?
#include <stdio.h>
#include <string.h>
#include <unistd.h>
#include <fcntl.h>
#include <errno.h>
#include <termios.h>
int fd,fd1,fd2,fd3;
int openport(void)
fd1=open("/dev/ttySAC2",O_RDWR|O_NOCTTY|O_NDELAY);
        if (fd1==-1)
                perror("open_port: unable to open port /dev/ttySAC2\n");
                return -1;
        else
                printf("open_port: succesfully open port /dev/ttySAC2\n");
                fcntl(fd1,F_SETFL,0);
                return 1;
void closeport(void)
close(fd1);
void configport(void)
struct termios options;
tcgetattr(fd1,&options);
cfsetispeed(&options,B115200);
cfsetospeed(&options,B115200);
options.c_cflag |=  (CLOCAL | CREAD);
tcsetattr(fd1,TCSANOW,&options);
options.c_cflag &= ~CSIZE;
options.c_cflag |= CS8;
options.c_cflag &= ~ PARENB;
options.c_cflag &= ~CSTOPB;
options.c_iflag &= ~(IXON|IXOFF|IXANY);
void writeport(int k)
char i[4];
i[0]='1';
i[1]='f';
i[2]='9';
i[3]=13;
//sprintf(i,"2f9",k);
write(fd1,i,sizeof(i));
//sleep(1);
int main()
int aa, k=0;
aa=openport();
configport();
while(1)
writeport(k++);
closeport();
return 1;
thanks
suresh
jrh_engineering
suresh,
I would recommend you attach you ARM9 board to a PC with a straight serial
cable from your ttySac2 adapter.  Make sure the receiving terminal
(Hyperterminal for PC or minicom for Linux) is set to 115200bps (8-N-1).
Send the command and see what you get.  An important thing to remember is
that the FriendlyARM is a DCE device (like a modem) whereas the PC is a DTE
device.  This means that the serial cable from the PC to the ARM board is a
straight cable versus the normal PC to PC null modem (crossover) cable.
Along the same lines, if you would normally use a straight cable to control
a device from the PC, you will need a crossover cable to control the same
device from your ARM board.  In other words, the cable supplied by the ARM
board will not work because this is a straight cable to communicate with a
PC.  Also, the cable that came with the motor controller, although it will
work with the PC, will not work with the ARM board, because it is also most
likely a straight cable (DTE-DCE).  Basically, whatever cable you would
normally use to talk to a device from the PC, you use the opposite for the
ARM board.
Also you can check fd1 in your code.  If it returns -1, the port never
opened.
James
david,
Any luck finding out how to move the debug data to another port?  I don't
think that sameer nalawade knows how to do this.  He only found out that it
had to be done.  His solution was to switch to the ttySAC2 port as have the
rest of us.
James
David
It has been almost two years that the above problem appeared. Has anybody
found any solution for above problem? I mean I would like to use my
ttySAC0. :-)
David
I have found the answer. You can find a file called inittab. In this file
there is a line:
“ttySAC0::respawn:/sbin/getty -L 115200 ttySAC0 vt100” which uses ttySAC0.
You can replace it with this: ttySAC1::respawn:/sbin/getty -L 115200
ttySAC1 vt100. (or ttySAC2 so on.)
This solve the problem. You can check whether it works or not with the
following simple script:
#/bin/bash
while true
do
  read LINE < /dev/ttySAC0
  echo $LINE
done
It works me fine.
Good luck,
David
Ajit
Hey David...
Where did you find that file named inittab??/
i cant find it.
Reggie
Almost certain he found it on www.google.com
Ajit
I think its a file present on mini2440
Juergen Beisert
If you run initV on your system, "/etc/inittab" controls the startup of the
system and also define possible login consoles.
