Hello, I have customized, fixed (e.g. the dm9000 network driver) and added some nice features (like buzzer driver, touchscreen support etc.) in the linux 2.6.33 kernel for the mini2440 board and made a public git repository (I also have stripped some unneeded files and directories). You can reach it under http://git.programmers-projects.de/?p=mini2440-dev.git;a=tree;hb=master Developers are welcome to improve stuff and fix some bugs if there are some. Compilation and booting should work fine. If you would like to join, you can create an account on http://www.programmers-projects.de The same account data you can also use to get write access to the repositories over webdav so you don't have to register twice. The address for accessing the project with your git client is http://<username>@git.programmers-projects.de/mini2440-dev.git Its planned to get the new QT embedded with a nice GUI working too. Sincerely Jay
New mini2440 project (kernel, tools, ...)
Thank you for making your work available. Just curious: I recall a DM9000 issue in the deep dark past, was this not fixed in 2.6.32.2? If not, what was the problem? Any GPIO and/or SPI support built in? Cheers, Dave
No problem, its my hobby and also git is good for backups and fixing stuff.
I have begun with the original 2.6.33 kernel (without patching the 2.6.32.2
source from friendlyarm) so I had to fix it manually. Now it is a
completely new mini2440 kernel tree with its own way and "style" ;)
Also the usb upload program is fixed and has some other little nice
features like percentage done and the memory should be freed correctly now
(in the original version, memory wasn't freed (correctly) before exit).
The next thing I will fix are the screen offsets (on my N35 display it's
not correct - there are black borders on the left and a little one on the
top).
Its surely this definition in the mach-mini2440.c file:
[0] = { /* mini2440 + 3.5" TFT + touchscreen */
_LCD_DECLARE(
7, /* The 3.5 is quite fast */
240, 21, 38, 6, /* x timing */
320, 4, 4, 2, /* y timing */
60), /* refresh rate */
.lcdcon5 = (S3C2410_LCDCON5_FRM565 |
S3C2410_LCDCON5_INVVLINE |
S3C2410_LCDCON5_INVVFRAME |
S3C2410_LCDCON5_INVVDEN |
S3C2410_LCDCON5_PWREN),
I don't know why it hasn't already been fixed :/
Can you please tell me the correct offsets?
Thanks.
Hello, maybe you would be interested in including the driver for the onboard camera as well? I am working on improved version : http://code.google.com/p/s3c2440camera/
Hi Jay, Would you please share the diff of your work? It would be great if I can patch your changes into my local source. Cheers!
Netzwerkchip-Treiber (DM9000) - Bugfixes (MAC-Addresse etc. angepasst) angepasst = adapted Any details? Offset problem: I would suggest digging into the patches that buserror has done to get issues like this sorted in the standard kerenel. Thanks, Dave
Hi Jay, Mabe my suggestion will be stupid, but do you plan to integrate VIA VNT6656 wifi module driver to your kernel? It would be nice! Thanks for your work
Okay, setting mini2440=3tb worked for me. It's the "T35" configuration but it seems to be correct. The camara support should work if you just copy the .ko file of the camera driver into the modules directory of mini2440 and do insmod. I will think about implementing the features told above. The problem is, that I havn't a camera or wifi adapter so I can't test if it works. Maybe another one would like to integrate these features (e.g. add files for camery support in drivers/media/video/ov9560) of the kernel tree and fix the Kconfig and Makefile of the )? As I said the changes can be synchronized with your local pc by using a Git client (you only need an account for getting write access). The address for reading the mini2440-dev repository with a Git client is http://git.programmers-projects.de/mini2440-dev.git (works over webdav).
Hint: the kernel camera driver will be loaded if you add 'c' to the mini2440= parameterstring (e.g. mini2440=3tbc will enable T35 display + touchscreen + backlight + camera interface).
I added the git snapshot download feature so you can download a snapshot of every directory you want.
That was fast. :-) Now, has this kernel tree suffered a lot of tweaking? [I'm asking this because I try to patch it with Xenomai and it's impossible, since so many (unneeded) files were removed (after partial Xenomai patching, I get an ugly error message).] So, what patch was it that you applied to the vanilla kernel in order to make it successfully compile and boot? Thanks.
Hi Jay, One more time, I have a "easy to say, not to do" sugestion : maybe it could be interesting to add a kind of generic driver which allow to drive each digitl or ADC I/O of the board. Original FriendlyARM board comes with a led driver, buttons and ADC1 channel drivers. I don't know if somebody has already developped something more generic for the moment, but it could be a nice idea. And this will offer many possibilities with your next step with Qt embedded To keep in mind? Thanks
I vote for Screwface idea : a kind of abstraction "driver" or utility that would drive the leds, buttons, and >SPI +I2C< . Big but really usefull work. Maybe we could start ourselves ?
The problem is that there is so much "hacked crap" floating about that we
will end up in a complete mess.
By "hacked crap" , I mean people going into kernel source and making
random and STUPID changes.
for example......
#if defined(CONFIG_ARCH_S3C2410)
printk("Now use the default MAC address: 08:90:90:90:90:90\n");
mac_src = "friendly-arm";
ndev->dev_addr[0] = 0x08;
ndev->dev_addr[1] = 0x90;
ndev->dev_addr[2] = 0x90;
ndev->dev_addr[3] = 0x90;
ndev->dev_addr[4] = 0x90;
ndev->dev_addr[5] = 0x90;
#else
mac_src = "eeprom";
There are ways to do this , and this is not it.....
mouha, If you take a look in the linux kernel there IS already an abstraction layer...... that allows reading and writing of this sort of IO by setting/reading flags in one of the linux directories.. possibly /dev/'somethignorother' if i remember rightly.
Right. There is already nearly everything compiled in you need (an own buzzer driver too as you can hear if you start the board). The leds can be found in the /sys/class/leds directory structure... Nearly everything that you can control you can find in the /sys/class system (in the newer linux kernels its standard).
I don't understand why all kernel developers I know use compiled in mac
address settings. there is an eeprom on the board (as far as I know its
1kB in size - I will only need the first 6 bytes for storing the mac
address). I try to implement a feature for storing (reading and writing)
the mac address there instead of the compiled in static one. I know, it's a
crazy idea but better than having things like this (as it actually is in
the dm9000 driver of my kernel tree):
1574 #if defined(CONFIG_ARCH_S3C2410)
1575 printk("Now use the MAC address: 1C:F7:1A:3D:89:E3\n");
1576 mac_src = "mini2440";
1577 ndev->dev_addr[0] = 0x1C;
1578 ndev->dev_addr[1] = 0xF7;
1579 ndev->dev_addr[2] = 0x1A;
1580 ndev->dev_addr[3] = 0x3D;
1581 ndev->dev_addr[4] = 0x89;
1582 ndev->dev_addr[5] = 0xE3;
1583 #else
1584 mac_src = "eeprom";
1585
1586 /* try reading the node address from the attached EEPROM */
1587 for (i = 0; i < 6; i += 2)
1588 dm9000_read_eeprom(db, i / 2, ndev->dev_addr+i);
1589
1590 if (!is_valid_ether_addr(ndev->dev_addr) && pdata != NULL) {
1591 mac_src = "platform data";
1592 memcpy(ndev->dev_addr, pdata->dev_addr, 6);
1593 }
1594
1595 if (!is_valid_ether_addr(ndev->dev_addr)) {
1596 /* try reading from mac */
1597
1598 mac_src = "chip";
1599 for (i = 0; i < 6; i++)
1600 ndev->dev_addr[i] = ior(db, i+DM9000_PAR);
1601 }
1602
1603 if (!is_valid_ether_addr(ndev->dev_addr))
1604 dev_warn(db->dev, "%s: Invalid ethernet MAC address.
Please "
1605 "set using ifconfig\n", ndev->name);
1606 #endif
it depends WHERE you got your tree.
Just check
kernel/drivers/net/
is there a "dm9000.c_old"
If so then this is not a pure linux kernel.
Iv'e been back to 2.6.25 and this is not in there, I understand what you
are trying to accomplish, but the only way you can be sure is by going back
to the vanilla linux and running a diff.
Because it could be that some of these hacks are actually stopping stuff
working once other mods are added.
it would also be good if you go and put all the other removed files back,
so that we are working with a standard set of kernel files.
As for the MAC address, this should be done in :
some thing like:
#if defined(CONFIG_MAC)
..... split it out here
#else
#endif
then implement a menuconfig as a changeable constant that is then parsed
into the source code, allowing a central access for changes without having
to continually DIFF the network files.
As it is , it is F***king stupid, requiring a "diff" of dm9000.c for every
different manufacturers board, because we all know how they like to
fiddle.......
I'm still trying to get the dm9k working:
getting
"IP-Config: No network devices available."
but it is showing up:
dm9000 Ethernet Driver, V1.31
TCP cubic registered
Just found why the network chip is not working, ---another dirty hack---
Any ideas what this is doing:
*((volatile unsigned int *)S3C2410_BWSCON) =
(oldval_bwscon & ~(3<<16)) | S3C2410_BWSCON_DW4_16 |
S3C2410_BWSCON_WS4 | S3C2410_BWSCON_ST4;
*((volatile unsigned int *)S3C2410_BANKCON4) = 0x1f7c;
#endif
(what values would it allocate?)
Nope!!!!!!
seems we may have a race condition...............
moving 1 line
&s3c_device_dm9k,
into "common-smdk.c" (where it should not be)
produces a working system:
dm9000 dm9000: dm9000_probe()
dm9000 dm9000: resetting device
dm9000 dm9000: dm9000 revision 0x19
eth0: dm9000a at c1804000,c1806004 IRQ 19 MAC: c0493934 (friendly-arm)
eth0: link down
IP-Config: Guessing netmask 255.255.255.0
IP-Config: Complete:
device=eth0, addr=192.168.2.30, mask=255.255.255.0,
gw=255.255.255.255,
host=192.168.2.30, domain=, nis-domain=(none),
bootserver=255.255.255.255, rootserver=192.168.2.101, rootpath=
Looking up port of RPC 100003/2 on 192.168.2.101
eth0: link up, 100Mbps, full-duplex, lpa 0x45E1
Looking up port of RPC 100005/1 on 192.168.2.101
VFS: Mounted root (nfs filesystem).
but moving
&s3c_device_dm9k,
into the board files mach-mini2440.c or mach-smdk2440.c
just produces:
This single change seems to have fixed all my issues related to the
networking.
Okay, but it seems to work for me with my kernel (and standard config file) because I have installed Qtopia from here and got the konqueror working for use with the internet :) The outputs from above doesn't seem to stem from my kernel source tree (because I have a different standard MAC address set) so I can't say what's wrong. Also I deleted some unused files because I wanted to get a smaller size of the kernel source tree. Please say what features youre missing and I will try to implement.
no the problem is not your files, The reason it does not match your "output" is that i have setup "friendly arm" to do a NFS boot...... The os is stored on a server, after the kernel boot of the FA it pulls the Android & the os from a central server. It was done this way so we could implement mass testing in a factory environment. It was after we started to get a few boards together we found "differences".
If I got plenty of time, I will try to get the 2.6.34 kernel working with some adaptations. I messed up some stuff locally so was glad that I have this git repository running on my server. Such a great comfortable invention for development! Hint: you can access and browse the git tree within your webbrowser (click on tree to show up directories and files; if you click the "blob" link, you can take a look into specific files). I also built in fancy syntax highlighting for webbrowsers. Just inform me about what you would like to improve or change so that I can make up the perfect mini2440 kernel. Its not only useful for me but for all of us :)
I finally got the android kernel running, just when it starts up, the LCD scrambles, but it is fine under linux. I thin we need to look more at getting the latest android, rather than chasing the latest kernel.
O.K ran into this with debug set: after starting android.... it appears that the "screen drivers" in s3c2410fb.c are being passed a size of ZERO for the lcd's Also the debug code in s3c2410fb.c is NOT displaying the correct values init: cannot open '/initlogo.rle' s3c2410fb: check_var(var=c0c4fda4, info=c048a800) s3c2410fb: resolution or depth on default display 0x0 at 0 bpp s3c2410fb: we were asked for 640x800 at 16 bpp s3c2410fb: wrong resolution or depth 640x800 at 16 bpp After applying the kernel fix here: http://permalink.gmane.org/gmane.linux.kernel.samsung-soc/965 finally android is being given the correct allocation from the kernel. init: cannot open '/initlogo.rle' s3c2410fb: check_var(var=c07c9da4, info=c048a800) s3c2410fb: resolution and depth on default display 640x480 at 16 bpp s3c2410fb: we were asked for 640x480 at 16 bpp s3c2410fb: pixclk 40000, divisor is 4 this is VERY dependent on the memory allocation and what is being loaded, as a result this bug will be dependent on "memoryalloc"
I have pushed my completely new 2.6.34 Linux Kernel onto the git repository. It should work fine because yesterday I already have compiled it successfully. Also it brings loads of customizations and more! You can use the default configuration by copying the config.save to .config. If you have a cross-compiler-toolchain, type make and see if it works. Please tell me if you have any problems while compiling and using specific features. Link: http://programmers-projects.de/project/mini2440-entwicklungsboard
Huh? Really? It is working for me. Try this please: http://programmers-projects.de/en/project/mini2440-development-board
I have experimented a little bit with the usb upload tool. Now it has a progress bar and it shows percentage done, upload speed, time elapsed, time left and so on (I only have tested my programming skills a little bit) :) It was complicated but now it's the best tool for uploading on mini2440 under linux I think ;) http://git.programmers-projects.de/?p=mini2440-dev.git;a=tree;f=usb_uplo... Maybe you can give me some advice to also improve the mini2440 config for my 2.6.34 kernel because something is wrong but I can't find the mistake :/ Here is the output while booting my customized kernel (look the error at the end): load Image of Linux...Uncompressing Linux... done, booting the kernel. Linux version 2.6.34 (julien@Optiplex) (gcc version 4.4.4 (Debian 4.4.4-2) ) #1 PREEMPT Sun May 30 13:59:09 CEST 2010 CPU: ARM920T [41129200] revision 0 (ARMv4T), cr=c0007177 CPU: VIVT data cache, VIVT instruction cache Machine: Mini2440 - ARM9 development board ATAG_INITRD is deprecated; please update your bootloader. Memory policy: ECC disabled, Data cache writeback CPU S3C2440A (id 0x32440001) S3C24XX Clocks, Copyright 2004 Simtec Electronics S3C244X: core 405.000 MHz, memory 101.250 MHz, peripheral 50.625 MHz CLOCK: Slow mode (1.500 MHz), fast, MPLL on, UPLL on Built 1 zonelists in Zone order, mobility grouping on. Total pages: 16256 Kernel command line: noinitrd root=/dev/mtdblock3 init=/bin/bash console=ttySAC0 PID hash table entries: 256 (order: -2, 1024 bytes) Dentry cache hash table entries: 8192 (order: 3, 32768 bytes) Inode-cache hash table entries: 4096 (order: 2, 16384 bytes) Memory: 64MB = 64MB total Memory: 59448k/59448k available, 6088k reserved, 0K highmem Virtual kernel memory layout: vector : 0xffff0000 - 0xffff1000 ( 4 kB) fixmap : 0xfff00000 - 0xfffe0000 ( 896 kB) DMA : 0xffc00000 - 0xffe00000 ( 2 MB) vmalloc : 0xc4800000 - 0xe0000000 ( 440 MB) lowmem : 0xc0000000 - 0xc4000000 ( 64 MB) modules : 0xbf000000 - 0xc0000000 ( 16 MB) .init : 0xc0008000 - 0xc0029000 ( 132 kB) .text : 0xc0029000 - 0xc04e2000 (4836 kB) .data : 0xc04fc000 - 0xc052b980 ( 191 kB) SLUB: Genslabs=11, HWalign=32, Order=0-3, MinObjects=0, CPUs=1, Nodes=1 NR_IRQS:85 irq: clearing subpending status 00000002 Console: colour dummy device 80x30 console [ttySAC0] enabled Calibrating delay loop... 201.93 BogoMIPS (lpj=504832) Mount-cache hash table entries: 512 CPU: Testing write buffer coherency: ok devtmpfs: initialized NET: Registered protocol family 16 Mini2440 features string [0..9=LCD; t=Touchscreen; b=Backlight; c=Camera]: mini2440=0tb Mini2440 Buttons: [0: ENTER ] [1: UP ] [2: POWER ] [3: LEFT ] [4: DOWN ] [5: RIGHT ] Mini2440 LCD: > 0: NL2432HC22 3.5" (0:240x320) 1: TD035STED4 3.5" (1:240x320) 2: AT056TN52 5.6" (2:640x480) 3: AT070TN83 7.0" (3:800x480) 4: VGA board (4:1024x768) S3C2440: Initialising architecture S3C2440: IRQ Support S3C24XX DMA Driver, Copyright 2003-2006 Simtec Electronics DMA channel 0 at c4808000, irq 33 DMA channel 1 at c4808040, irq 34 DMA channel 2 at c4808080, irq 35 DMA channel 3 at c48080c0, irq 36 S3C244X: Clock Support, DVS off s3c-adc s3c24xx-adc: attached adc driver bio: create slab <bio-0> at 0 SCSI subsystem initialized usbcore: registered new interface driver usbfs usbcore: registered new interface driver hub usbcore: registered new device driver usb s3c-i2c s3c2440-i2c: slave address 0x10 s3c-i2c s3c2440-i2c: bus frequency set to 98 KHz s3c-i2c s3c2440-i2c: i2c-0: S3C I2C adapter Advanced Linux Sound Architecture Driver Version 1.0.22.1. Bluetooth: Core ver 2.15 NET: Registered protocol family 31 Bluetooth: HCI device and connection manager initialized Bluetooth: HCI socket layer initialized cfg80211: Calling CRDA to update world regulatory domain NET: Registered protocol family 2 IP route cache hash table entries: 1024 (order: 0, 4096 bytes) TCP established hash table entries: 2048 (order: 2, 16384 bytes) TCP bind hash table entries: 2048 (order: 1, 8192 bytes) TCP: Hash tables configured (established 2048 bind 2048) TCP reno registered UDP hash table entries: 256 (order: 0, 4096 bytes) UDP-Lite hash table entries: 256 (order: 0, 4096 bytes) NET: Registered protocol family 1 Slow work thread pool: Starting up Slow work thread pool: Ready NTFS driver 2.1.29 [Flags: R/W]. ROMFS MTD (C) 2007 Red Hat, Inc. msgmni has been set to 116 alg: No test for stdrng (krng) io scheduler noop registered io scheduler cfq registered (default) Console: switching to colour frame buffer device 40x29 fb0: s3c2410fb frame buffer device s3c2440-uart.0: s3c2410_serial0 at MMIO 0x50000000 (irq = 70) is a S3C2440 s3c2440-uart.1: s3c2410_serial1 at MMIO 0x50004000 (irq = 73) is a S3C2440 s3c2440-uart.2: s3c2410_serial2 at MMIO 0x50008000 (irq = 76) is a S3C2440 brd: module loaded loop: module loaded at24 0-0050: 1024 byte 24c08 EEPROM (writable) S3C24XX NAND Driver, (c) 2004 Simtec Electronics s3c24xx-nand s3c2440-nand: Tacls=3, 29ns Twrph0=7 69ns, Twrph1=3 29ns s3c24xx-nand s3c2440-nand: NAND hardware ECC NAND device: Manufacturer ID: 0xec, Chip ID: 0xd3 (Samsung NAND 1GiB 3,3V 8-bit) Creating 4 MTD partitions on "NAND 1GiB 3,3V 8-bit": 0x000000000000-0x000000040000 : "boot" 0x000000040000-0x000000060000 : "param" 0x000000060000-0x000000560000 : "kernel" 0x000000560000-0x000040000000 : "root" tun: Universal TUN/TAP device driver, 1.6 tun: (C) 1999-2004 Max Krasnyansky <maxk@qualcomm.com> dm9000 Ethernet Driver, V1.31 No MAC-adress set - using default: 1C:F7:1A:3D:89:E3 eth0: dm9000e at c4864300,c4868304 IRQ 51 MAC: 1c:f7:1a:3d:89:e3 (mini2440) ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver s3c2410-ohci s3c2410-ohci: S3C24XX OHCI s3c2410-ohci s3c2410-ohci: new USB bus registered, assigned bus number 1 s3c2410-ohci s3c2410-ohci: irq 42, io mem 0x49000000 usb usb1: New USB device found, idVendor=1d6b, idProduct=0001 usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1 usb usb1: Product: S3C24XX OHCI usb usb1: Manufacturer: Linux 2.6.34 ohci_hcd usb usb1: SerialNumber: s3c24xx hub 1-0:1.0: USB hub found hub 1-0:1.0: 2 ports detected Initializing USB Mass Storage driver... usbcore: registered new interface driver usb-storage USB Mass Storage support registered. usbcore: registered new interface driver libusual s3c2410_udc: debugfs dir creation failed -19 s3c2440-usbgadget s3c2440-usbgadget: S3C2440: increasing FIFO to 128 bytes mice: PS/2 mouse device common for all mice input: gpio-keys as /devices/platform/gpio-keys/input/input0 s3c24xx-ts s3c2440-ts: driver attached, registering input device input: S3C24XX TouchScreen as /devices/virtual/input/input1 input: buzzer as /devices/platform/buzzer/input/input2 S3C24XX RTC, (c) 2004,2006 Simtec Electronics s3c2410-rtc s3c2410-rtc: rtc disabled, re-enabling s3c2410-rtc s3c2410-rtc: rtc core: registered s3c as rtc0 i2c /dev entries driver Linux video capture interface: v2.00 S3C2410 Watchdog Timer, (c) 2004 Simtec Electronics s3c2410-wdt s3c2410-wdt: watchdog inactive, reset disabled, irq enabled cpuidle: using governor ladder sdhci: Secure Digital Host Controller Interface driver sdhci: Copyright(c) Pierre Ossman s3c-sdi s3c2440-sdi: powered down. s3c-sdi s3c2440-sdi: mmc0 - using pio, hw SDIO IRQ usbcore: registered new interface driver hiddev usbcore: registered new interface driver usbhid usbhid: USB HID core driver No device for DAI UDA134X No device for DAI s3c24xx-i2s S3C24XX_UDA134X SoC Audio driver UDA134X SoC Audio Codec asoc: UDA134X <-> s3c24xx-i2s mapping ok ALSA device list: #0: S3C24XX_UDA134X (UDA134X) TCP cubic registered Initializing XFRM netlink socket NET: Registered protocol family 17 lib80211: common routines for IEEE802.11 drivers s3c2410-rtc s3c2410-rtc: setting system clock to 2010-05-30 18:21:15 UTC (1275243675) yaffs: dev is 32505859 name is "mtdblock3" yaffs: passed flags "" VFS: Mounted root (yaffs filesystem) on device 31:3. devtmpfs: error mounting -2 Freeing init memory: 132K Failed to execute /bin/bash. Attempting defaults... Kernel panic - not syncing: No init found. Try passing init= option to kernel. See Linux Documentation/init.txt for guidanc. [<c002f920>] (unwind_backtrace+0x0/0xf0) from [<c03d4958>] (panic+0x58/0xd8) [<c03d4958>] (panic+0x58/0xd8) from [<c00295e4>] (init_post+0xac/0xd4) [<c00295e4>] (init_post+0xac/0xd4) from [<c0008474>] (kernel_init+0x118/0x158) [<c0008474>] (kernel_init+0x118/0x158) from [<c002af84>] (kernel_thread_exit+0x0/0x8)
your file system is not being mounted. just a tip........ STOP messing about with these flashed storage for development, eventually you will see bad blocks on the nand flash...... then you will be in real trouble. Instead use NFS, it is faster cleaner, and preserves your hardware.
Just for information: bad blocks are normal on NAND flash media. I have scanned with u-boot and I have only see 4 bad blocks. So this isn't the problem. Also I use a special flash filesystem called YAFFS2. This handles these bad blocks, moves bad blocks (on non-bad-blocks) and makes it secure against data loss... It says "VFS: Mounted root (yaffs filesystem) on device 31:3" so I think it's mounted cleanly. Why you think a NFS storage is a better alternative? I don't think that it will be really faster because I already got it working (with another, older customized kernel) and it was faster than I thought. I think it's just a mistake in the configuration that I maybe have overlooked.
Hi Jay, I think bob wanted to explain that during development phase, you may have to flash your filesystem image many times and this could damage your flash chip as it is made to support a finite average number of write/erase cycles.
Okay, then its clear. But why the kernel doesn't continue booting? Supervivi is flashed, the Kernel is flashed and also the root filesystem (embedded debian for arm) is flashed... The boot parameters (noinitrd init=/bin/bash root=/dev/mtdblock3 console=ttySAC0 mini2440=1tb) seem to be correct... Can you please explain me, what's wrong? Here are the last actual lines of debug info: --------------------------------------------- TCP cubic registered NET: Registered protocol family 17 s3c2410-rtc s3c2410-rtc: setting system clock to 2010-05-31 21:16:37 UTC (1275340597) yaffs: dev is 32505859 name is "mtdblock3" yaffs: passed flags "" usb 1-1: new full speed USB device using s3c2410-ohci and address 2 hub 1-1:1.0: USB hub found hub 1-1:1.0: 4 ports detected VFS: Mounted root (yaffs filesystem) on device 31:3. Freeing init memory: 132K Failed to execute /bin/bash. Attempting defaults... Kernel panic - not syncing: No init found. Try passing init= option to kernel. See Linux Documentation/init.txt for guidanc. [<c002fa54>] (unwind_backtrace+0x0/0xf0) from [<c02cfa78>] (panic+0x48/0xd0) [<c02cfa78>] (panic+0x48/0xd0) from [<c00295cc>] (init_post+0xac/0xd4) [<c00295cc>] (init_post+0xac/0xd4) from [<c0008474>] (kernel_init+0x118/0x158) [<c0008474>] (kernel_init+0x118/0x158) from [<c002af4c>] (kernel_thread_exit+0x0/0x8) ----------------------------------------------- After I got it with cross-compiling qt-4.6.2 I will try it first with the 2.6.32.2 kernel from here. I think at least this will work. But the error, that the kernel can't continue booting, must be fixed.
try: 1. re flashing each area. 2. rolling back to your last set of working code. Personally jay I would not try and chase the latest kernel, they have stripped out certain items related to ADC With kernel updates you are on a never ending hamster wheel, you will get 2.6.34 finished and working just in time for 2.6.35 It may be more productive to stabilize at a lower kernel , but to push on with the latest android >2.0. work on LCD /sound/ADC support/wiireless/bluetooth, and speed. on the Nand-flash, there really is a lot of background that you are not aware of, nand -flash is not the bastion of reliability you think it is, the fact that you found 4 blocks > "1mb" of bad space does not take into account random read/write anomalies, and the general unreliability of nand flash technology.
Yes, youre right, bob. The 2.6.33 Kernel worked just fine. I made a big mistake by trying it with the 2.6.34 Kernel because I think that it is "to new". And also the Version 2.6.35 of the Kernel has begun. Also I know that NAND-flash media are not as reliable as they should be for writing on the same areas more than 1 million times or so. But the kernel needs to be on the OnBoard NAND as far as I know. Thank you for the advices! I will try to give my best because I know that it already has worked with the 2.6.33 Kernel so I will turn back to this version. Also it will be faster, uses less RAM and will support most bluetooth and wireless and all OnBoard-devices (including speaker driver, status LEDs, nicier console outputs and better backlight support). I don't know if Android is really better than a "normal", good styled QT-GUI. As far as I know you can't use normal Linux-applications under Android (because it uses a java virtual machine for its base). That's the biggest disadvantage. So I have planned to get a nice QT-GUI working on top of a debian rootfs with the 2.6.33 Kernel as its base.
Finally I got the "new" 2.6.33 kernel working with qpe :D I have wondered that I have got it so optimized (with qpe started it only uses 24MB RAM): Mem: 24380K used, 36156K free, 0K shrd, 0K buff, 13164K cached And wow, it's so damn fast :) I like work and experiment with it. It's so cute this board ;)
yes , stick with 2.6.33 get all the bugs out and a stable system (watch long term memory allocation) then look at moving kernel later but just to be clear the android is an application that sits under linux. If you want to "run" linux apps , just close down the Android and revert back to linux.(busybox is linux) The advantage with android is the fact that you can program in semi-java , so there is a lot less work to be done on the GUI side, also there are no license fees if you go commercial. other than that if you use LGPL you MUST share all the code. I find QT-GUI a real pain and not as good looking. Then there is the licensing issue, for Hardware hackers and home brew stuff I would say android, ideally it needs to be something the kiddies can play with.
How is Qt's performance on this kernel? The embedded Widget demo is a good starting place: http://qt.nokia.com/files/embedded-widget-demos/qt-embedded-widgets-catalog Use this video http://www.youtube.com/watch?v=n62555v6m3Y as a reference for speed, since it uses the "factory default" kernel
Maybe someone could make a benchmark test or something like that to compare between my kernel (with standard configuration) and another one. But I will never use another kernel than my own again. The best for me is that, what I have made myself (because then I have a better overview).
Of course Jay. I ask about performance because I compiled buserror's kernel, everything worked just fine, but Qt's performance was very slow compared to the default kernel (in the video). I need to investigate more why that happens, just wondering if the same happens in your kernel... if it does, maybe friendly arm is doing some hacking that we are not aware of in the framebuffer part
I don't think that it also is a problem in my kernel because it's just working great. Also usb, buzzer, buttons, touchscreen and framebuffer device. It also has more "style" at startup because it e.g. shows you the button configuration (which button is for what) and the selected/all available screen types (actually 5 are implemented - including external VGA board). But I am not so glad that I also had to "hack" the dm9000 driver (because I havn't seen another possibility to get it working - but now it's working good). I have tried to "hack" as few things as possible.
Great, unfortunately i don't have the time now to test your kernel and check qt's performance now, i will do that test when my schedule here allows it. For now, ill just use a modified filesystem of the factory default system.
Yes, I think the factory default is good at the beginning. But the problem is, that there is so much untidy stuff in it.
Hello all, I'm using the latest 2.6.33 git from above and I am having trouble booting off the SD card. After mounting the ext3 partition it oopses hard: mmcblk0: mmc0:7f37 SD04G 3.69 GiB mmcblk0: p1 p2 p3 kjournald starting. Commit interval 5 seconds EXT3-fs (mmcblk0p3): using internal journal EXT3-fs (mmcblk0p3): recovery complete EXT3-fs (mmcblk0p3): mounted filesystem with writeback data mode VFS: Mounted root (ext3 filesystem) on device 179:3. Freeing init memory: 120K Unable to handle kernel NULL pointer dereference at virtual address 00000018 pgd = c0004000 [00000018] *pgd=00000000 Internal error: Oops: 5 [#1] last sysfs file: Modules linked in: CPU: 0 Not tainted (2.6.33-mini2440 #8) PC is at __gpio_get_value+0x18/0x40 LR is at s3cmci_card_present+0x1c/0x38 pc : [<c01436c4>] lr : [<c01c95f0>] psr: 20000013 sp : c3981e40 ip : 00050151 fp : 00000000 r10: 00000000 r9 : 00000008 r8 : c3981f0c r7 : 00000001 r6 : c3981ea0 r5 : c383e1a0 r4 : c0023070 r3 : c036c280 r2 : 00009f19 r1 : 0007752c r0 : 00000000 Flags: nzCv IRQs on FIQs on Mode SVC_32 ISA ARM Segment kernel Control: c000717f Table: 30004000 DAC: 00000017 Process mmcqd (pid: 724, stack limit = 0xc3980270) Stack: (0xc3981e40 to 0xc3982000) 1e40: 00000000 c01c95f0 c383e000 c01ca4a0 c3981ea0 c383e000 00001000 c01bef0c 1e60: 0000049d 00000064 00000000 c383e800 00100100 00000000 c3981e78 c3981e78 1e80: c3978a24 c3953640 c397b000 00000001 c3978a24 c01c4aec 00000001 c0328590 1ea0: c3981eb4 c3981f0c c3981ee0 c3981e74 c01befa4 00000012 0036c710 00000000 1ec0: 00000000 00000000 00000000 000000b5 00000000 00000000 c3981f0c c3981ea0 1ee0: 0000000c 00000000 00000000 00000000 00000000 00000000 0000049d 00000000 1f00: 00000000 00000000 c3981ea0 05f5e100 00000000 00000200 00000008 00000000 1f20: 00000200 00000000 c3981ee0 c3981ea0 00000001 c383e800 00000000 c012ec68 1f40: 00000002 c395d800 c39850a8 c3953640 00000111 c012f8dc c38ff840 00000000 1f60: 00000001 c3978a24 c38ff840 c3978a2c c3953640 c3978a24 c38ff840 c3953640 1f80: c01c56b8 c01251cc c38ff840 c3953640 c3978a24 c3980000 c3978a2c c38ff840 1fa0: c38ff9a0 00000000 c3953640 c01c56b4 00000000 c3875e38 c3981fd4 c01c55cc 1fc0: c3978a24 00000000 00000000 c004c740 00000000 00000000 c3981fd8 c3981fd8 1fe0: 00000000 00000000 00000000 00000000 00000000 c0027e8c 00000000 00000000 [<c01436c4>] (__gpio_get_value+0x18/0x40) from [<c01c95f0>] (s3cmci_card_present+0x1c/0x38) [<c01c95f0>] (s3cmci_card_present+0x1c/0x38) from [<c01ca4a0>] (s3cmci_request+0x28/0x8c) [<c01ca4a0>] (s3cmci_request+0x28/0x8c) from [<c01bef0c>] (mmc_wait_for_req+0x1e8/0x210) [<c01bef0c>] (mmc_wait_for_req+0x1e8/0x210) from [<c01c4aec>] (mmc_blk_issue_rq+0x1b0/0x4f8) [<c01c4aec>] (mmc_blk_issue_rq+0x1b0/0x4f8) from [<c01c56b4>] (mmc_queue_thread+0xe8/0xec) [<c01c56b4>] (mmc_queue_thread+0xe8/0xec) from [<c004c740>] (kthread+0x78/0x80) [<c004c740>] (kthread+0x78/0x80) from [<c0027e8c>] (kernel_thread_exit+0x0/0x8) Code: e0010190 e59f3028 e1a02000 e7910003 (e5903018) ---[ end trace ec56cfc268b2f5c2 ]--- Any ideas?
I'm sorry but my kernel only has in it's standard-configuration yaffs2 as filesystem compiled in because the EXT filesystems are not so good for use on flash devices (only for mechanical hard drives). But they (EXT2/3/4) are available as modules so you need to install the modules correctly. The Kernel is only tested for using it on the OnBoard-NAND. Maybe in a newer version I will change the configuration a little bit if these filesystems are essential for you.
hello, could you plz make a snapshot (in tar.gz) on your git site ? because I'm behind a powerful firewall in the office. thanks
I added the snapshot link for downloading source trees as snapshots (in tar.gz format) again. Another problem is left: the MAX811 reset doesn't work properly I think. Anyone has an idea how to solve this?
The Main Project Page can be found under http://www.programmers-projects.de/projekt/mini2440-entwicklungsboard. The releases of the project can be found under http://www.programmers-projects.de/node/33/release. All german texts can be translated by selecting a language in the GTranslate block on the right side of each page.
Have you monitored the output of the MAX811 to determine this or ?? Do you mean that when you push the reset button, that it doesn't reset?
@davef: I meant that it doesn't reset properly if I want to restart via the "shutdown -r now" command. So I think it is a problem in the kernel (or in its configuration) that it can't trigger the reset through the MAX811 IC. The reset button works without problems so it is no big problem but I would like to solve it.
I don't see how any external control lines, except the manual reset pin, would influence MAX811 behaviour. All it does is monitor the supply voltage and when it drops below a certain level gives you a logic level that you can use to control the operation of external devices.
Ah I see. But my kernel also needs a working software reset (not only hardware reset). Can you please give me some advice to get it working? Either there is missing some code for software reset in the kernel or the configuration has a mistake in it. If the kernel tries to reset the board, it only shows some backtrace messages of memory addresses.
Who, me? Sorry, wouldn't know where to start. Well, actually I went to familiar ground at AVRfreaks (8bit AVR) and did a search, as that topic came up quite often and found: *** Search this site for "software reset" and the like. Short answer: Enable the watchdog timer and go into an eternal loop. *** Somehow, me thinks there is more to it then this, but maybe it is a place to start. Good luck
Touch screen is not working properly for the 7" LCD... Also the MMC module crashes. pgd = c3c08000 [f96f7ea4] *pgd=00000000 Internal error: Oops: 5 [#1] PREEMPT last sysfs file: /sys/devices/platform/s3c2440-sdi/mmc_host/mmc0/mmc0:0002/block/mmcblk0/mmcblk0p 1/dev Modules linked in: CPU: 0 Not tainted (2.6.33-mini2440 #1) pc : [<c01bb1e0>] lr : [<c0274958>] psr: 20000013 sp : c3b03e30 ip : 00000200 fp : c3b03e90 r10: c3b02000 r9 : c39b5ea4 r8 : 00000015 r7 : c3b03f54 r6 : c3b03e90 r5 : c383f1a0 r4 : c0023070 r3 : c045f940 r2 : 6f6e2073 r1 : 4e4a6159 r0 : 6f6e2073 Flags: nzCv IRQs on FIQs on Mode SVC_32 ISA ARM Segment kernel Control: c000317f Table: 33c08000 DAC: 00000017 Process mmcqd (pid: 684, stack limit = 0xc3b02270) Stack: (0xc3b03e30 to 0xc3b04000) 3e20: c0023070 c0274958 c383f000 c0274f08 3e40: c3b03e90 c383f000 c3b03e54 c0268444 c3975640 00000000 c3b03e58 c3b03e58 3e60: c399bc00 c3975640 0000000d c026e5a4 ffffffff ffffffff ffffffff 00000001 3e80: ffffffff 00000000 c3b03ea4 ffffffff c3b03ea4 c3b03efc 00000000 c3b03e54 3ea0: c0268588 00000011 0000003f 00000000 00000000 00000000 00000000 000000b5 3ec0: 00000000 00000000 c3b03efc c3b03e90 0000000c 00000000 00000000 00000000 3ee0: 00000000 00000000 0000049d 00000000 00000000 00000000 00000000 05f5e100 3f00: 00000000 00000200 00000001 00000000 00000200 00000000 00000000 c3b03e90 3f20: 00000001 c383f800 c399e400 c39812c0 00000000 0000003c c399e400 c3975640 3f40: 000001b1 c3b00150 00000000 c01a3e9c 00000001 00000001 c383201c c3b02000 3f60: c39812c0 c3b03f84 c3b02000 c39812c0 c3b03f84 00000000 c3975640 c01981b8 3f80: c3b02000 c3b02000 c39b5ea4 00000001 c3981420 00000000 c39812c0 c39b5eac 3fa0: c3975640 c026f0ac 00000000 c387fe20 c3b03fd4 c026eff4 c39b5ea4 00000000 3fc0: 00000000 00000000 00000000 c0054060 00000000 00000000 c3b03fd8 c3b03fd8 3fe0: 00000000 00000000 00000000 00000000 00000000 c0028fd0 ffffffff ffffffff Function entered at [<c01bb1e0>] from [<c0274958>] Function entered at [<c0274958>] from [<c0274f08>] Function entered at [<c0274f08>] from [<c0268444>] Function entered at [<c0268444>] from [<c026e5a4>] Function entered at [<c026e5a4>] from [<c026f0ac>] Function entered at [<c026f0ac>] from [<c0054060>] Function entered at [<c0054060>] from [<c0028fd0>] Code: e92d4010 e59f302c e0801080 e1a02000 (e7930101) ---[ end trace 7292bec1c302ae59 ]---
@mobyfab: Thank you for testing and the report. I think it is a problem in the configuration of the kernel because there I used the IRQ instead of the generic polling code when inserting a SD/MMC card. At the moment, just for testing purposes. In the next configuration update I will fix this besides some other improvements.
What do you mean by "touchscreen isn't working properly"? Isn't it working or is it working wrong (like the directions are wrong for up/down and/or left/right - this could be fixed in userspace)?
Hi all I am trying to do image processing using mini2440. I successfully cross-compiled opencv and got 4 directories generated: include bin share lib As i am running qtopia 2.2 rootfs on my board, i copied contents of the above 4 directories to those in the board fs (for eg. bin to /bin of board) Is this ok? will it work this way or do I need to make the rootfs again? Also how to test whether the opencv is working or not? PS. I'm actually a newbie Tan
Hi, great work Jay, I'm looking to port kernel 2.6.36, but ts don't work. Let me know if you start from version 2.6.33 downloaded from www.kernel.org vanilla ? Where i can download your kernel 2.6.34 for mini2440 ? Thanks
Well I already post patches to lkml to add new display types also ts working for newest kernel but it's still not accepted (also without comments). Also post patches to buserror which make 2.6.32-rc8 kernel changes and he promise to push it to maintainer but still nothing. Hate this way of working. Sad. Anyway you can find patches in lkml just search for mini2440 ;) marek
Hello! After long time I decided to My customized 2.6.33 linux kernel + usb upload tool for mini2440 is now downloadable at ftp://gediam.de/projekte/mini2440/ It has different but easier compilation/installation process (see README file). Please post any errors/difficulties and/or improvement suggestions here. If I have more time, I will see to get a newer kernel (2.6.38 or so) running on mini2440 to also customize it a little bit. My goal is to get the newest kernel (with newest YAFFS2 fs) running on mini2440 because of improvements made in newer kernel versions. So my question also is if you already got a kernel higher than version 2.6.33 running? Thank you for any replies!
Jay, Tried to download the kernel and it hung on the last few bytes. If anyone has successfully downloaded it I would like to know before trying again. Cheers, Dave
Jay, When I came back to the "almost" finished download an hour or two later I noticed that it had completed. Now, I just need to find a copy of mkimage. Thanks, Dave
Jay, Recompiled for JFFS2 and it does run. It takes quite a long time to get to the log-in prompt. About 3-5 times longer than the kernel I got from: http://www.sendspace.com/file/6gdbp2 uImage http://www.sendspace.com/file/zxfgyq rootfs.tar.gz Thanks to Ivan on this thread: http://www.friendlyarm.net/forum/topic/2106 I have noticed that on a few of the recent uImages floating around, that when you are using minicom you don't get any console messages until the login prompt on the mini240 touchscreen. If it is appropriate it would be useful to see the messages flying past as it fires up the rootfs. Didn't try your compilation process as I couldn't find your README file. After I got it working I had another look and found your comments in INFORMATION. Regards, Dave
Hello, what I have uploaded is an older backup of the modified kernel. The newest one got lost so I only uploaded the one I could find. The links are interesting. Because of there are many other good kernel projects, I won't continue my kernel project. But the SQLite DBMS and extended USB-Upload-Tool you can find on my website could be more interesting.
Hi Joe, I am a newbie to mini2440. Recently I have downloaded the kernel 2.6.33 from your repository. I have imported the T35 configuration file provided with the mini2440 to your kernel. The images are successfully built and I have downloaded into FLASH. But when I try to boot from NAND flash, it gives load Image of Linux...Uncompressing Linux... done, booting the kernel. and stucks. Can anyone guide me. Thanks.
Hello Tarjun, do you have given the right console in the boot parameters (console=ttySAC0)? Where do you see this message? Is it on the Screen of Mini2440 or in the RS-232 console?
Hi All, I am facing one issue that DM9000AEP is not getting detected using Linux 2.6.32.2. I am getting following Error when I am try boot the Kernel with Dm9000aep driver. dm9000 dm9000 read wrong id 0x46464646 dm9000 dm9000 wrong id 0x46464646 dm9000 dm9000 not found (-19) Can anybody help me in solving this issue. Base address or Address mapping of DM9000 is 0x18000300-0x18000303 & 0x18000304-0x18000307
