Hi I will project the picture processing. Counting the number of cars on the road with cameras. I want to know. Mini2440 supports that or not using linux.
mini2440 work in image processing?
Hi Nave Now I'm working at a project called Eye Tracking System. The main task of mini2440 is to detect the eye in continuous frames get from a web camera connected through USB. I'm using an image processing library called OpenCV. It's manufactured by Intel. I can get a speed of 20~25 fps without any processing and after processing I get the eye coordinates with a speed of 5 fps. But in your case you will have more computations than me. I suggest you to develop a part of project (detect a car for example) and to run it on PC machine. You can monitor the time and you we'll able to decide if the ARM S3C2440 can perform your computations. Regards azzido
Thank azzido. I recently began to study. Have to bother with. OpenCV you use linux on the surface data and the programs you run on the board of linux mini2440 it or not. If I do not irritate your e-mail you? Thanks.
Dear all, I am the same one want to using ARM9 to build project about image processing. but i don't have any data of its. i will registration the training courses for using it on Linux OS and WinCE OS. I am not sure about possible of the image processing on ARM9 and Is it too difficult? Have you the example project to using this? pls. give me at j_phetchuen at yahoo dot com. Very thankyou. Naja
@Nave: My e-mail address is p.nicusor@yahoo.com @Naja: It's not so difficult if you use a library for image processing like OpenCV. But what do you want to do ? Using an USB camera ? You can find a lot of examples searching on google with "OpenCV example" Regards, azzido
You need a good software math processor (aka floating point emulator) because image processing (especially with motion) mostly needs lots of calculations to crop, rotate, zoom in/out etc. but the arm9 has no integrated one as far as I know. There are flying good software floating point emulators around in the internet. I prefer to use the FastFPE one (it's not as precise as NWFPE but very fast).
Jay, you right. I used EABI that is included in arm-linux-gcc 4.3.2 from CodeSourcery. Regards, azzido
Hi all, I'm working on a program to extrapolate gaussian information from the CMOS camera. I can get almost 50 fps streaming to video and 20 fps with the maths running. I m only on 320 x 240 atm and I need more speed. Was talking to Vladimir Fonov over the weekend who sent me his driver for the CMOS camera which is excellent, and he is sending me another one shortly which does YCbCr and RGB. Is anyone interested in starting a little page where we can exchange specific "image processing" information? Cheers Paul
Oh forgot :P I went from 18.7 to 23.54 fps by switching all doubles to floats, unless you really need the accuracy. Its easy to do, just do a Replace All "double" with "float" then patch up. Naturally, this includes redeclaring all decimals as floats: 0.0 -> 0.0f Works for me Cheers Paul
hi guys, i m currently working on image processing. i m using MATLAB for writing algorithms , i want to know that which ARM9 processor will be suitable for me . i don't know much more a bout ARM9 , so pls help me out..
Hey Paul, Mind sharing the libraries? I want to use the setup to do some line following in a very bright noisy environment. You can mail me the libs at sidchinoy222 (at) gmail (dot) com Thanks. PS: I think the image processing page is a good idea. let's start it!
Hi AZZIDO! I'm also doing mmini2440 with image processing and tried to project : Eye tracking.Before I worked with open CV on my PC, it works well but now, when I used mini2440,it has many problems. could u help me some questions: 1> Do i have to rebuild openCV or not? how to load into board 2> How to run simple program using library openCV. ( I also write some simple codes but when building, it doesn't work) . Thanks and hope to get ur answers soon Nice day!
Paul Matteucci can you send me your OpenCV source tree so that i can compile it? The one I have keeps give me invalif instruction. valdimir could you share you new driver ? Thanks all
Hi all I was wondering how to increase the window size of the usb camera window, so that it maximizes on the whole screen.Any help will be appreciated. Thanks
Can anybody send me the OpenCV configuration file for Mini2440 ? My OpenCV code gives invalid instruction when run and I susoect it is some config option. I am sure the generated code is ARM but it sitll keeps giing me invalid instruction.
hi I'm doing my final year project using arm9 additionally i decide to do image processing mini2440 friendly arm . if anyone having idea about give suggestion to me as well as if possible give source code for image processing Thanking you
Hi, I am working on real time edge detection using ARM9 mini 2440. Is it possible to implement C code on ARM9
Hi Shanshank, Yes it is possible to run edge detection using opencv on mini2440...can support u contact at k.sundeep2007@gmail.com, as this forum is only for friendlyarm product related
