s3c2440a
kppp
dear all,
i have a arm board of s3c2440a from friendlyarm.
i am using IDE of metrowerks code warrior for arm developer suite v1.2.
i have started the PLL and timer. but i am unable to start interrupt.
i did all the initialisation for interrupt sam as the way it is shown in
the sample program. i am attaching my code for the reference. pls gothrough
my code and help me out
thank you
regards
PS: in case of any queries pls let me know.
here is my code:
#include "def.h"
#include "option.h"
#include "2440addr.h"
#include "2440lib.h"
#include "2440slib.h"
#define  EnableIrq(bit)    rINTMSK &= ~(bit)
#define  DisableIrq(bit)    rINTMSK |= (bit)
#define  EnableSubIrq(bit)  rINTSUBMSK &= ~(bit)
#define  DisableSubIrq(bit)  rINTSUBMSK |= (bit)
void delay(unsigned int i);
void initialise(void);
void init(void);
void __irq timer0isr(void);
void MMU_SetFastBusMode(void);  //GCLK=HCLK
void MMU_SetAsyncBusMode(void); //GCLK=FCLK @(FCLK>=HCLK)
void HaltUndef(void);
void HaltSwi(void);
void HaltPabort(void);
void HaltDabort(void);
void HaltIrqabort(void);
void HaltFiqabort(void);
void ClearPending(int bit);
void ClearSubPending(int bit);
void enable_IRQ(void);
 rGPBDAT = 0x141;
 rSRCPND = BIT_TIMER0;       //Clear pending bit
 rINTPND = BIT_TIMER0;
 unsigned int a,b;
 for(a=0;a<i;a++)
 b = 0;
void init(void)
 unsigned char mdiv,pdiv,sdiv;
 mdiv = 0x5c;  //settings for 405MHZ operation for M PLL
 pdiv = 0x01;
 sdiv = 0x01;
 rMPLLCON  = (mdiv << 12);
 rMPLLCON |= (pdiv << 4);
 rMPLLCON |= sdiv;
 mdiv = 2;
 pdiv = 0;
 rCLKDIVN  = (mdiv << 1);  //FCLK = 405MHZ (MPLLCON setting), HCLK = FLK/4
= 101MHz, PCLK = HCLK/2 = 50MHz, UCLK = UPLLCON (as it is 48MHZ reqd)
 rCLKDIVN |= pdiv;
 mdiv = 0x38;  //settings for 405MHZ operation for M PLL
 pdiv = 0x02;
 sdiv = 0x02;
 rUPLLCON  = (mdiv << 12);
 rUPLLCON |= (pdiv << 4);
 rUPLLCON |= sdiv;
 pISR_UNDEF=(unsigned)HaltUndef;
 pISR_SWI  =(unsigned)HaltSwi;
 pISR_PABORT=(unsigned)HaltPabort;
 pISR_DABORT=(unsigned)HaltDabort;
 pISR_IRQ   =(unsigned)HaltIrqabort;
 pISR_FIQ   =(unsigned)HaltFiqabort;
 rINTMOD=0x00000000;    // All=IRQ mode
 rINTMSK=BIT_ALLMSK;    // All interrupt is masked.
 rPRIORITY = 0x00;
 rSUBSRCPND = 0x00000000;
 rINTSUBMSK = 0xffff;
 rCLKCON = 0xfffff0;
int Main(int argc, char **argv)
 int i;
 i = 0;
 for(i=0;i<100;i++)
  delay(10000);
 for(i=0;i<100;i++)
  delay(10000);
 for(i=0;i<100;i++)
  delay(10000);
 for(i=0;i<100;i++)
  delay(10000);
 for(i=0;i<100;i++)
  delay(10000);
 for(i=0;i<100;i++)
  delay(10000);
 init();
 //initialisation of the interrupt
 ClearPending(BIT_TIMER0);
 rPRIORITY   = 0x7f;
 pISR_IRQ    = (unsigned int)timer0isr;
 pISR_TIMER0 = (unsigned int)timer0isr;
 //timer initialisation:
 //Timer input clock Frequency = PCLK / {prescaler value+1} / {divider
value}
 rTCFG0  = 0x000000ff;    //prescalar = 255 + 1
 rTCFG1  = 0x00000003;    //divide by 16
 rTCNTB0 = 30000;        //down counter
 rTCMPB0 = 500;
 rTCON   = 0x00000000;
 rTCON   = 0x0000000b;    //AR INV UPDT START
 rTCON   = 0x00000009;
 EnableIrq(BIT_TIMER0);
 delay(100);
 //port initialisation:
 rGPBCON = 0x155556;    //tout0 = gpb0
 rGPBUP  = 0x7ff;      //pullup disable
 rGPBDAT = 0x0000a0;
 //|AR|INV|UPDT|START|
 //if set inverter on,  when TCNT2<=TCMP2, TOUT is low,  TCNT2>TCMP2, TOUT
is high
//if set inverter off, when TCNT2<=TCMP2, TOUT is high, TCNT2>TCMP2, TOUT
is low
 for(;;)
   i = 0;
 return 0;
  while(1);
void HaltSwi(void)
  while(1);
  while(1);
  while(1);
  while(1);
  while(1);
  register i;
  rSRCPND = bit;
  rINTPND = bit;
  i = rINTPND;
  register i;
  rSUBSRCPND = bit;
  i = rINTPND;
kppp
hello evryone,
can you pls help me in my problem:
thank you
kemalony
I think most of ppl are developping under any OS
kppp
hi,
thanks for reply.
i want to know that interrupts are implemented under OS only or without OS
also it is implemented.
because i did implementation of interrupts in arm7 without OS and there it
is working fine.
is there any address of interrupt is missing?
pls tell me.
thank you a lot for the reply
regards
kokono
hi everybody. i'm using mini2440 now and it makes me confused. i installed
linux on my PC( ubuntu 9.10) and began programming. But i don't know how to
program, which language i should use, which IDE i can use. i also installed
Code Block as an IDE but i can't create an GUI on it. do anyone tell me
more specifically ? thanks a lot.
MMI
Hi Im developing a application to display images in LCD.  Can anyone pls
suggest me how to do this using Keil. Also, pls suggest how to flash the
compiled .bin file to mini2440 board with bootloader. Also, if there is any
initial settings to be done in keil, pls reply with that too.
Thanks in Advance.
