Hello, I was making some tests, and I noticed that the serial port control from vbnet is too slow under wince! Is there a better (faster) way to read data from the serial port? Thank you all Fernando
Serial port
I'll explain a little more the situation: with the serial port open and receiving continuesly data (4800 bps, 300 bytes per second), the rest of the application slows down. I have a main loop where I increment a variable and print it each time the loop begins, and without the serial port (or the device not sending data) it goes around 10 times per second in the loop. With the serial data enabled, it goes 1 or 2 times per second. I tried to set the rxthreshold to bug numbers, like 300 bytes or more, but is the same... Could this problem be a limitation of the platform more than a problem? Thanks all, hope somebody can help me... the most sad thing is that this is happening with just one comm, and I need to use the three of them :S
4800bps is what we used back in the 70's. Should be no problem at all for the arm. Made you can show use some code.
I'm not a vb.net genius, but i heard some things about the poor performance of stream drivers used by a managed application (vb.net or c#). I wonder if a solution couldn't be to write an unmanaged dll in c to administer the serial port and export functions to exchange data with the managed application. It's the idea I have, but I never made such a thing (it's for these reasons I write my applications in c/c++) domodom
Hi Edje and domodom, I solved this issue... the ActiveSync connection was slowing down that much the application! I closed the link and the application runs ok! My imstake.. :$ By the way... domodom, how would be to write an unmanaged dll in C? its interesting but I dont have a clue... and it sure could be useful for some things. Thank you all!!! Again!
Hello Fernando, Someone contacted me on my website to have advices to write a c# application that use serial port. It's the guy who sent me the c# version of my GPIO sample application. If it is possible for you, could you post your application here (or just the interesting part of your source code ?) Best regards Domodom
Hi domodom, The code I'm posting is defined inside a class (that is because I will use the three serial ports, each one for a different type of device)... First of all, I create the serial port control: Private WithEvents sp As New System.IO.Ports.SerialPort In the class constructor, I initialize the serial port: Try With sp .PortName = "COM2" .BaudRate = 4800 .Parity = IO.Ports.Parity.Odd .StopBits = IO.Ports.StopBits.One .ReceivedBytesThreshold = 20 .DiscardNull = False .Open() End With Catch ex As Exception _mensajes = "ERROR PUERTO" End Try Then, the event handlers: Private Sub sp_DataReceived(ByVal sender As Object, ByVal e As System.IO.Ports.SerialDataReceivedEventArgs) Handles sp.DataReceived Dim cantidad As Integer cantidad = sp.BytesToRead sp.Read(datos_rx, 0, cantidad) RECEPCION(cantidad) End Sub Private Sub sp_ErrorReceived(ByVal sender As Object, ByVal e As System.IO.Ports.SerialErrorReceivedEventArgs) Handles sp.ErrorReceived sp.DiscardInBuffer() End Sub The sub RECEPCION reads the data and tries to find the header of the rx frame, then process the data... etc Hope it helps! Just ask if you need more about this.
private void serialPort1_DataReceived(object sender, System.IO.Ports.SerialDataReceivedEventArgs e) { byte ini = 126; byte[] escopo = new byte[1]; { do { serialPort1.Read(escopo, 0, 1); // lon } while (!(escopo[0] == ini)); { serialPort1.Read(xbeeByte.rxbbee1, 0, serialPort1.BytesToRead); // NI 0, 85 EncodingXbeeData(); serialPort1.DiscardInBuffer(); // <<<!!!!! } } } fernando... fijate en el discart bufer... si no haces eso s blokea despues de un tiempo! andres
Hi Andres (te escribo en ingles para que de paso si le sirve a alguien, bienvenido sea) Your system blocks after some time if you dont discard the buffer? How much time does it take to hang? that's one of the tests I have to do, actually I have it running now... If you let me, I want to mark some things in your code... you are waiting for certain data "inside the interrupt"... what is better, from my point of view, is read all the data present in the buffer, store it in another buffer, and then in the main loop process the buffer, search for the start byte, etc. that way, when you exit the interrupt, the read buffer is totally readed and no need to flush the buffer. What do you think? Saludos! Fernando (Argentina, y vos?)
hi can any body helpe im trying to make an aplication that can read the serial port, so im trying to execute the comtest but i cant do it work here is the steps i made: i compile the comtest example with this line: arm-linux-gcc -o comtest comtest.c it made a file call comtest and after that i send the file comtest to the mini and now i trying to execute with this line ./comtest but this is the messeage mistake: Unable to open device streero() is no No such file or directory what can i do? pd: yo tambien hablo español soy de colombia jejeje
hola David (muchos latinoamericanos eh!! :) ) I cant help with linux... did you try in the linux forum?
hola fernado. if… without doubts better and but it is ordered to do it of the way that you indicate, but as they run by ways I am using separated it thus, so that it did not give problems me si... sin dudas es mejor y mas ordenado hacerlo de la manera que indicas, mas como corren por vias separadas lo estoy usando asi , por que no me dio problemas as far as the time that was blocked.? it watches does not pay attention to him. but I am solved when it cleaned bufer en cuanto al tiempo que se bloqueaba..? mira no le preste atencion .. mas se me soluciono cuando limpiaba el bufer and if I am using to the program at the moment to verify it 4 units xbee that they pertencen to an alignment system, and transmit the data of his 2 sensors ccd and a clinometer of 2 axes each head ;. argentino tambien . solo que viviendo en brasil.. o playas lindas!!!! jejejj
Hello Fernando, Thank you very much to have posted your code with your explanations. I will try to find time to write a tutorial on my web site. domodom
Whenever you want Domodom, if you need anything else for this or other tutorial, just let me know. I will be glad to help you in whatever I can. Fernando
Hi Fernando Im interested in the complete source code cause Im new with the VB programming and the serial port issues so I would like to see your full code as a guide so I can develop my own codes and learn about, if you could make an attachment it could help me a lot. Thanks
Hi MexFer, what you see is the complete source for getting data from the serial port. The rest of the code (like the RECEPCION sub) is the code for doing something with the received data, but that depend of your application. If you write the above code, you will be reading data from the serial port :) Did you try to do something with it already? Regards, Fernando
=O not really I thought there should me something else =P, Im going to read it and try to understand it =). By the way by naming "COM2" the port name you are using the fisical com2 (Serial TTL of the board?) Thanks
Yes, COM2 the serial port that is available in the board. You can use it in TTL levels (in CON2) or RS232 levels (from the DB9). Regards, you are welcome. Fernando
Well I have a problem this is the code Im using I do some changes cause my VB get me some errors... Public Class Form1 Private WithEvents sp As New System.IO.Ports.SerialPort Dim datos_rx() As Char 'I got an error that this variables werent Dim _mensajes As String ' declared Private Sub sp_DataReceived(ByVal sender As Object, ByVal e As System.IO.Ports.SerialDataReceivedEventArgs) Handles sp.DataReceived Dim cantidad As Integer cantidad = sp.BytesToRead sp.Read(datos_rx, 0, cantidad) TextBox1.Text = cantidad ' I want to put the data in a text box. End Sub Private Sub sp_ErrorReceived(ByVal sender As Object, ByVal e As System.IO.Ports.SerialErrorReceivedEventArgs) Handles sp.ErrorReceived sp.DiscardInBuffer() End Sub Private Sub TextBox1_TextChanged(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles TextBox1.TextChanged End Sub Private Sub Button1_Click(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles Button1.Click Try With sp .PortName = "COM2" .BaudRate = 4800 .Parity = IO.Ports.Parity.Odd .StopBits = IO.Ports.StopBits.One .ReceivedBytesThreshold = 1 .DiscardNull = False .Open() End With Catch ex As Exception _mensajes = "ERROR PUERTO" End Try End Sub End Class Nothing happens, I dont know if everything is ok, from the CPU I use this conf: Baud Rate: 4800 Port: COM1 Parity: Odd Data Bits: 8 Stop Bits: 1 Software Flow Control: None Hardware Flow Control: ¿? Dunno exacty what to put here... Hope this info is complete and hope you can help me. Thanks
Just a couple of minor things, as I am no VB expert. You seem to be wanting to use COM2 in the code, but try to conf. COM1 (typo)? Hardware flow control: None (for RS232)
Hi MexFer, in your code you are writing to your textbox the quantity ("cantidad" in spanish), of bytes that were available in the serial port. declare datos_rx as a buffer of byte (not char) and give it a size (1024, for example). You should have no problem. Did you debug to see if your serial port is opened or is throwing and exception? Fernando
Hi everyone. I want to share some code from me. This code is work 100% for WinCE6 and I atteched a project for everyone. Public Class Form1 Delegate Sub InvokeDelegate() Private Sub serialPort1_DataReceived(ByVal sender As System.Object, ByVal e As System.IO.Ports.SerialDataReceivedEventArgs) Handles serialPort1.DataReceived ' Declare Thread Function textBox1.BeginInvoke(New InvokeDelegate(AddressOf updateTextbox)) End Sub Private Sub updateTextbox() Dim tmp As String ' Get value from SerialPort tmp = serialPort1.ReadExisting ' Set text to TextBox textBox1.Text = textBox1.Text + tmp End Sub
Hi thanks everyone for your answers. =) ------------------------------------------------------------------------- For "davef": Yep I try changing to COM1 and still not working. -------------------------------------------------------------------------- For "Fernando": I made the change you suggest, the code remain the same just I change this: Dim datos_rx() As Char for this: Dim datos_rx(1024) as Byte Dunno exactly if I made right with you try to explain me: "declare datos_rx as a buffer of byte (not char) and give it a size (1024, for example)." Im not very familiar with the VB language =P First I made some tests between two computers running a SerialData program and it works once I learn about a little bit I try to use the FriendlyARM board. ------------------------------------------------------------------------- For "ToonCoolMan": From the code you attach I get some errors... I copy the code from the Form1.vb and paste it into a new project I manually add a serialport, a timer and a textbox and I get some error messages before generate: at cmdConnect.Click, cmdDisconnect.Click and cmdSend.Click the error is the same in the three cases: "Handles clause requires a WithEvents variable defined in the containing type or one of its base types" The three errors are marked as when you type something wrong in word xD then I put the mouse on top and appears the error messege I type above. From the code you type on the message I copy it and paste it into a new project, add a serialport and a textbox, generate it and run it on my platform board (Wince 6.0) and doesnt work either =S ------------------------------------------------------------------------- Thanks everyone for your comments and help, hope with your help I could get more info about what Im doing wrong. Thanks, nice day. ^^
Update. I get the message errors from the cmdConnect and so right =) kinda newbie stuff (wich is normal cause Im newbie in VB xD ) Goin to see if it works in the board. =)
Update2. I use the program attached by "ToonCoolMan" I was able to generate and run the exe between my computer and the board and doesnt work, so I try the program with the serial cable bypassed RX with TX with an UTP cable so the same data send will be recieved by my board and it works but if I then connect the cable with the computer doesnt work. Im using a crossed serial cable, Could it be something between the exe from my FriendlyARM board and the exe Im using from the computer ?? Thanks, and have a nice day.
Hi MexFer, I didn't understand completely what's your situation right now... joining the TX and RX terminals of the mini2440 you receive what you are sending, or this happens in the PC and not in the mini board?
Joinin TX and RX on the mini2440 works fine with the program Im using but if I connect the mini with the pc the same program doesnt work ... =S
Yes, it works fine while I test em individualy but when I join them with the serial cable it doesnt work, I think it could be the serial cable itself but first I test it between 2 cpus and works fine. Thanks.
Did you check voltage levels? Are you sure you are using in both TTL levels or in both RS232 levels? Are you sure both comms are configured exactly the same? Besides this, I think that there are no more things that can be the problem. Fernando
Hey David! I have the same problem as yours. Did you manage to solve it? Does anyone know which is the problem? Thanks in advance. Mc_bimi
i could put it to work serial port using the C examples, i modified the code to it could use the com1 instead of com0, put the cables on this port and it works!. i hope this can help you!!
I need example code about serial port from vistual studio 2005 ( C# ) it work for win ce 6.0 anyone help me ?
Well first of all thanks for everything but the problem was the desktop cpu I was using I switch to another to communicate with the friendlyarm and it works, but something strange I notice is that it works using the serial cable that comes with the board wich I tested and its not a crossed serial cable so I dont know how could this be =P. Hope you can help me to understand that issue, besides that it works fine =) In the mean time Im going to try to communicate using the CON2 port wich uses 3.3 TTL (I guess) with a Microchip PIC18F and the serial protocol, hope I could handle it. Thanks.
Hey David!! Thank you for your answer!! you only modified the comtest.c code and you got it. That's nice! I'll try!!(espero que funcione! jeje) lets see if I am capable! Mc_bimi (Spain)
Fernando perdon que me meta en su conversación solo quiero ayudar un poco. Aunque no trabajo con esta placa si he trabajado con otras placas y he desarrollado muchos proyectos usando el puerto serie desde hace mas de 12 años 1ero usando VB6 y actualmente usando VB.Net y bien si reconosco que la velocidad de VB.Net es menor que haciendo la aplciacion en VB6 pero no tanto. Tengo un proyecto embbedido en la MoBo Alix1C usando XPe con el framework 2.0 y usando dos puertos seriales al mismo tiempo el uso del procesador no pasa del 20% y el sistema se siente bastante bien. Ha donde quiero llegar con todo esto? bueno pues que cuando recien empece con VB.Net hace unos... mas bien desde VS2000 me di cuenta que usand el evento DataReceived la captura serial era muy muy lenta, pero como asi lo venia haciendo con VB6 no me quedo otra que dejarlo asi, despues modifique mi codigo para que en ves de usar el evento DataReceived(en VB6 OnComm) dice una clase que en un Hilo estubiera todo el tiempo revisando si hay datos en el pueto serie, es decir dejame ver si me explico mejor con un pedazo de codigo. Private Sub LeeDatos() Dim strDatos As String = "" Do While 1 Try If Not m_oPuerto.IsOpen Then Exit Do strDatos = m_oPuerto.ReadLine() RaiseEvent RecibeDatos(strDatos & m_oPuerto.NewLine, False) Catch ex1 As System.TimeoutException Try If m_oPuerto.BytesToRead > 0 Then If m_intSendLenMax > 0 Then If m_oPuerto.BytesToRead >= m_intSendLenMax Then 'El caracter de Nueva Linea no llega asi que se envian los datos recabados en el buffer strDatos = m_oPuerto.ReadExisting RaiseEvent RecibeDatos(strDatos, True) End If End If End If End Try End Try Loop End Sub El metodo LeeDatos esta corriendo en un Hilo por separado y como uedes ver es infinito hasta que se cierre el puerto. en la linea strDatos = m_oPuerto.ReadLine() el sistema se espera hasta que el carcter definido en la propiedad NewLine llege al puerto entonces continua, e spro esta razon que tiene que ser ejecutado en un Thread si no tu sistema se dentendria, bueno en caso de que tu caracter no llege en un tiempo dado pr la propiedad ReadTimeout se genera un error la System.TimeoutException y en tonces el codigo toma otra ruta haora se pregunta si han llegado almenos X numero de bytes al buffer y en caso de que asi sea los lee en caso contrario vuelve a esperar otro tiempo para que llege el caracter de nueva linea, se que esto es medio complicado y engorroso pero asi obtiene un rendimiento 5 veces o mas superior. espero que no te confunda mas y disculpa mi ingnorancia en la ortografia y en lo demas pero no soy letrado como dicen por aca. Saludos D@niel T. Mexico D.F.
Buen dia Daniel! Muchs gracias por tus comentarios sobre como resolviste el tema del puerto serie, y te cuento que yo tambien lo termine resolviendo de esa manera hace varias semanas!! :) Es bueno saber que la manera en que lo resolvi tambien fue una que le dio resultados a otras personas. yo tambien vengo de trabajar durante muchos años con VB6, y hace solo algunos meses me pase a VBNET. Como decis vos, la lectura del puerto serie en los eventos generados era realmente muy lenta. Mas cuando estaba recibiendo de 3 puertos series datos ininterrumpidamente. A partir de haber creado el hilo de lectura del puerto serie el programa corre muy pero muy bien. Si bien ya lo tenia resueslto, agradezco mucho tu aporte, ya que esto es muy importante en los foros. Estoy pensando en crear un grupo de facebook por ejemplo para poder compartir este tipo de informacion, ya que veo que hay muchos hispanos que participamos de los foros. Muchas gracias de nuevo, saludos. Fernando
Me gustaria ver ese grupo en el facebook!! jajaja y q se vea un poquito de español por aca tambien jajaja
Bueno acabo de crear el grupo, quien quiera unirse busqueme en facebook, Fernando Blaha. Les mando luego la invitacion. Saludos!!
ToonCoolMan, thanks a lot for the code attached,.. it works. You saved a lot of my time :) Thanks again.
Hola Fernando, yo soy de Argentina también, mas especificamente de San Martin, Bs. As. Hace poco que adqurí mi placa, en realidad no es una mini sinó un TQ2440 de Boradcon. Pero muchas cosas de las que utilizan aca me son útiles. Espero que nos mantengamos en contacto. Saludos
Hola Diego, te dejo mi mail: fb@blaha.com.ar Yo estoy en Villa Urquiza, asi que estamos cerca. La compraste para algo en particular la placa, o solo para "jugar"? Saludos
Hi everyone... I've a problem..I wrote a program about serial communication for s3c6410 series..I'm using ttl port..When I start the program com2,com3,com4 and com5 is active and I'm connecting my device to com2 ttl port..But there is no signal, no action..when I try the test program it says I/O exception..please help me..
and also I wanna load the prolific serial to usb converter driver to my embedde pc..I downloaded the driver from the prolific website..But I have no idea how can I load it...
I suggest you make a consult to domdom... he is the light out there for many os uf :) http://www.domodom.fr/spip/index.php I know he was working with the 6410 and I think he said that he had some issues with the serial ports...
Hi all, I have downloaded a sample about SerialCom of ThaiEasyElectronic. When i run .exe file in my board, it get an error: "An error message cannot be displayed because an optional resource assembly containing it cannot be found" Can you help me solve this issue, thanks.
for tonncoolman hello,you should use the different events for different module such as receive,send and connect,dissconnect use same data binding given in the code ... thanx
